My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone
I've been working on simplifying the wiring harness by pulling connector pins/sockets. I finally got the knack of popping the latch holding the pin/socket in the housing. My cheap set of eyeglass screwdrivers work better than the $11 set of EBay connector tools I bought.
After a few days of hacking and chopping wires I got the engine harness whittled down to where it cranks, sparks and the fuel pump runs all without blowing a fuse nor causing any conflagration (fire). Once it warms up a bit, I plan to roll the chassis outside, add some gas to the tank and see if it runs. :thumbsup:
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #163
Thanks for keeping us up on this Garauld. I'll post a photo of my tracked machines if you like. We have snow here.
-> Yes, please do.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #165
Here is some machines that I've operated over the years. Only the 6x6 is mine personally which is the last photo...
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #166
I like the red one!
I like the red one!
-> Me too! What hp and drive system does it have?
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #168
Copied from PBullys web site. Its sure hard to copy and past here! In the below info you can see they a hydrostatic transmission. The new ones might have 5 or more pumps in them.
https://www.pistenbully.com/fileadm...d/Fahrzeuge/gebrauchte_pistenbully_en__1_.pdf
3PistenBully 100. The multi-talent.PistenBully 100
Model year:1999 – 2010from 2010Engine:Mercedes-Benz
OM 904 LA with elec-tronically controlled fuel injection system (EUROMOT 3A, EPA TIER 3)
Mercedes-Benz OM 924 LA with elec-tronically controlled fuel injection system (EUROMOT 3A, EPA TIER 3)
Cubic capacity:4,250 cm34,820 cm3Power output (ECE):129 kW (176 hp)145 kW (197 hp)
Max. torque:675 Nm at 1,200 – 1,500 rpm705 Nm at 1,200 – 1,600 rpmFuel consumption:from 8.5 l/h
Fuel tank capacity:150 lWidth over tracks:2,500 / 2,740 / 3,100 mm
Width over tiller:from 3,100 mmHeight when driver's cabin tilted:3,020 mmGround clearance:approx. 320 mm
Load area:1,620 x 1,920 mm Tare weight:from 3,600 kg depending on the tracks
Gross weight limit incl. attachments:5,200 kgPayload on platform:1,000 kgSpeed, infinitely variable:0 – 25 km/h
Spec. ground pressure:from 0.051 kg/cm2 depending on the tracksGround coverage with tiller:37,500 m2/h
Brakes:No mechanical wear using hydrostatic transmission. Two multi-disc parking brakes.
Attachments front:Quick change system with All-Way-Blade
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #169
Cool thread! Nice job!
It is a nice day here in upstate NY so I rolled Snowzer out of the shop in an attempt to see if it would run. After putting a couple gallons in the fuel tank and a bit of cranking, viola - it actually ran! :thumbsup: I moved the shifter arm through its paces and the axle CV housings moved appropriately. I do have a small atf drip leak that is probably located where I split the diff housing to I weld it up. This will need to be addressed at some point.
EXCAVATOR QUICK DISCONNECT (A58216)
EXCAVATOR QUICK...
1998 CAT 140H Motor Grader (County Owned, Cat Maintained) (A59213)
1998 CAT 140H...
2018 John Deere 4066R (A53314)
2018 John Deere...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
30KW GENERATOR (A58216)
30KW GENERATOR...
