My Ride-on Tracked dumper
   / My Ride-on Tracked dumper
Motor and pump installed. Dump and plow spool, fuel tank positioned. Some diamond plate rubber mats glued down. Working under a tarp in 104F with humidex.
   / My Ride-on Tracked dumper #183
Many of us wait with baited breath for it to move under its own power
That's for sure. But he is doing something which I could never do.......
...Waiting until after it's completely painted and finished before playing with it.:laughing:
Welcome to my nightmare. Really hoping to get this thing running this weekend. Dropped another 1,500 in hydraulics in the past week. Nothing fits, too many adapters. At least 100 places it could leak. Everything I built mounts for has to be moved because the hoses are not flexible enough for the close quarters. Some things need ORB 10, ORB 8, ORB 6 and ORB 16. Others need 3/4 NPT, 1/2 NPT and 1 1\4 NPT.
   / My Ride-on Tracked dumper #185
Good grief!! I wonder if the space shuttle has that many hoses and levers. Good luck working it out.
   / My Ride-on Tracked dumper #186
I can never do that either. I'm not totally done with my backhoe, and I just had to play with it.
Still need the bucket hoses. I tried to hold out until I got the last hoses and the bracing done. But no. I had to hop on it and play in the dirt. :laughing:
I dug a 2 feet deep by 5x5 hole. My dad asked me what I was digging a hole for? I told him, no reason the hole needed dug, I was just playing in the dirt with my new toy. :laughing:
I dunno, I might dig it a bit deeper and wider once I get my bucket curl hoses and throw some trash and brush down in there and burn it. Before I cover the hole back up.
Then it will be on too the digging for a purpose. "The water line". lol
Hope you get to play with your new toy soon David.
Chad
   / My Ride-on Tracked dumper #187
All I can say is Wow!! You have more talent than I ever dreamed of having. That is awesome
Well I got it together and sort of working. I am in vacation mode and will not be able to investigate, modify for another month. The status is, I need proper 5L belts, substituted 4L but the narrower belts don't grip. Thus belt slipage at 1500 PSI. Temp solved with tightening tensioner. Unable to build more then 1500 PSI, so has trouble turning in dirt. OK on hard surface but paved driveway protested. I have a few Pressure relief vavles to adjust, all supposedly set at 2000 PSI at factory but appears to be 1500.
I may have to change reduction chain drive to 3:1 from 2:1. All the discussion about teflon paste vs teflon tape. From now on its tape all the way and I have been repairing leaky paste connections with teflon tape. Also tape will always let you do one more full turn to correctly clock a connection. Better yet try and avoid NPT fitted componets. ORB ones are not leaking. Anyway it looks sweet sitting on its trailer.
   / My Ride-on Tracked dumper #190
Very cool, and NPT fittings of any kind are evil in my book. Give me ORFS, ORB, or JIC any day. Heck, I'd rather use BSPP before NPT.
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
William Nash HB-1030 10ft Hy-Brid Electric Scissor Lift (A50322)
William Nash...
Year: 2007 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 2 Door (A51692)
Year: 2007 Make...
2023 TAKEUCHI TB370 EXCAVATOR (A51242)
2023 TAKEUCHI...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
