My Ride-on Tracked dumper
   / My Ride-on Tracked dumper #171
As much as I want to see it run, I have to vote for paint first.:laughing:
   / My Ride-on Tracked dumper #172
X2 for paint it first. Paint wont stick to hydraulic oil spilled on metal. Spilled hydraulic oil will stick just fine to paint.
   / My Ride-on Tracked dumper #173
I agree, while we all wait with baited breath to see a video of it in operation we also don't want you to have to do more work than necessary, specially since you had to fab up all those parts over and over.
We will wait :thumbsup:
   / My Ride-on Tracked dumper #175
Can't wait to see the tracked dumper in operation. I've almost got my backhoe done. I got most of the hydraulics working.
I've also got another idea for my backhoe which may not happen until a few years from now. "That's when I should have the money".
But the idea is to do away with it mounted on the mower and build a separate frame for it and make it hydraulically driven like your dumper.
What I would like to do is make it a bit like a mini excavator. :drool: I would like to also add a cab with heat for in the winter time as well. And make a push blade on the bottom.
I may or may not add tracks to it. We'll see when the time comes.
If I do make the backhoe into a mini ex then I'll be at least $3,000.00 in the project. But I think it will be worth it.
Chad
Chadd, you don't need a heater, you don't get winter in Kansas:)
Anyway, here is a shot of my homemade belt tentioner for the double belts that will drive the pump. As well, now that I am running reduction gearing for the track motors, I built chain guards. Finally have the main welding completed and have primed the frame. Not easy manuvering when working out of a shoebox. I can't believe its May and still only +7 C 45F. Not to mention its raining.
I should be able to start buying hydraulic hoses in two weeks if I can keep motivated.
   / My Ride-on Tracked dumper #177
Looking good David. Keep it up. You're almost home free.:thumbsup:
I am slowly putting this thing together. Working in a shoe box means continuously moving things around which will get harder and harder as i start adding weight to the machine. Here is a shot of the frame painted and then the cab installed. Bringing the machine outside shows all the spots I missed with paint. Oh well, I am sure to have lots of touch ups as I go.
   / My Ride-on Tracked dumper #179
Looking good David, especially reviving the curved dash Oldsmobile look of 1903. :thumbsup:
   / My Ride-on Tracked dumper #180
It's looking impressive, can't wait to see it in action.:thumbsup:
I know what you mean by working out of a shoe box. My shop hardly even qualifies as a shoe box. I've have had to dissemble projects each night to get them to fit back in the shop.
DIRTDOG CBX60 5' BOX BLADE (A51243)
DIRTDOG CBX60 5'...
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
Wolverine Mini Skid Steer Grapple (A50515)
Wolverine Mini...
Wolverine Quick Attach 68" Bucket (A50515)
Wolverine Quick...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
