My Ride-on Tracked dumper
   / My Ride-on Tracked dumper #1
David Devuono
Platinum Member
Brampton, On\lot Powassan, ON Canada
Kubota B4200\MF 135\Kubota B3200
Been waiting a long while for the right tire at the right price to come along. Finally it did and I picked up 20 tires (13.5x5x6). each can support 370 lbs. Each track will have 10 tires. 8 road wheels and 2 tensioning wheels + metal drive wheels powered by hydraulic motors. Each of the 8 road wheels per side will be paired and mounted on upside down trailer leaf springs, two springs per side.
I have now two hydraulic motors, one big pump, a cylinder for a dump bed, my road wheels, four leaf springs. Now I need to source some 4-6" belting, two pieces per side connected with cleats tied together with 3/4 rod to engage the driving gears. Will be two weeks before I start assembly. Looking to haul 1000 lbs of dirt, plow, and tow a X-country ski groomer in the winter. Approx 4 feet by 8 feet?
   / My Ride-on Tracked dumper #2
Sounds like a fun project. What kind of motor are you gonna use?
I was looking at a 10 HP diesel but now thinking something around 15 hp gas as I don't think the small diesel has a glow plug and I want to use it in the winter as well. Either can be had for around $500. Anyway keeping my eye open for a good deal. Both those engines might be too small for my 10GPM at 2500PSI pump?
   / My Ride-on Tracked dumper #5
years ago I saw where a guy got to older tractor tires, and cut the sides walls nearly off, leaving a little side wall, and used the 2 large rear tractor tire for a set of tracks, over a set of small tires for drives, alway thought it was neat idea,
I was give a home made snow machine about 40 years ago, and the guy used two sets of belting, and bolted oak slats to it, and then for drive sprockets , he used aluminum plate with tire rubber for filler, there were about 2 inch's wide, I think there was a strip of flat iron as well under the slats,
in the military they made track sections that would work on a duel tired 6x6 truck and they look like belting and a 2" channel bolted to them, there in sections so one can use on different trucks some what similar to these Tandem Axle Track Systems - Right Track Systems Inc.
   / My Ride-on Tracked dumper #6
also you could check with a grain elevator many times they have used belting they may have taken out of a leg,
   / My Ride-on Tracked dumper #7
Keep this thread updated as you build. This one looks cool...
   / My Ride-on Tracked dumper #8
When you get it rolling bring it to Bancroft for a test drive......
Sounds like fun, but I'm a little nervous about those 3/4" rods bending if one side rides up on a stump in the snow. Have you considered 2" channel or similar? Easy to fasten the belting to as well.....
The 3/4 rod will be used to hook into the drive gear. It will be welded to plates that will be bolted to the rubber tracks. Final design not determined, I suppose I could try channel but then I would have to custom built some drive gears to engage the channel. My plan is to double up 3/4 pitch #60 gear wheels on each side to engage the Rod. I can envision 3/4 Rod welded to 2" channel though. This thing will have suspension which I can adjust by adding or removing leaf springs. It should flex somewhat over obstacles and there will likely be a Rod every 4-6 inches with channel for traction and grousers below to keep the track on the wheels. Anyway when the time comes I will look at all options for track, up to and including chain & plate tracks like on the tracked wheel barrow I made a few years ago, though they are less snow friendly and very heavy.
   / My Ride-on Tracked dumper #10
Hello, Im always interested in tracked vehicles. I often thought of making one myself. I have quite a few J5 bombardier tracked machines. Very good machines. I have done hydraulics only a little, but noticed you were wondering about the size of your engine. I believe your engines would be too small for your pump and flow rate. HP needed would be about
Horsepower = (Pressure in PSI x Flowrate in gpm )/1714
so = (2500 x 10gpm)/1714
= 15 hp
And due to inefficiency and such you would probably stall the engine quite a bit when pulling maximum. Use a larger engine, maybe 18 or 20. Or cut your flow or pressure down to compensate for the smaller motor.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
KUBOTA M6800 TRACTOR (A51243)
KUBOTA M6800...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
