My Quick-Attach won't Detach... Dangit!
/ My Quick-Attach won't Detach... Dangit! #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Guys, Friday I had to switch to the forks in a hurry, and they are always a bit tight. When they arrived years ago, I had to grind out the hole on one side just to fit.
Well they were on but I could not get the latch to latch locked, so I stomped on it...
Well now I cannot get it to release, the lever simply will not come out of the locked position...
Any suggestions???
/ My Quick-Attach won't Detach... Dangit! #3
Disconnect the two connecting pins from the arms.
(The arms often push the pins unevenly.)
Lube pins well. Kroil or another light oil is good.
Hit the bottom of the pins with a nylon mallet, if you can access.
If not, use a brass drift to access the bottom of the pins, then hit drift with a mallet.
/ My Quick-Attach won't Detach... Dangit! #5
First thing, spray penetrating oil on every pivot... They look dry to me. Then take a hammer and smack upward on both pins holding the attachment on.
This,
my ssqa looks just like that one. After I use it especially if I'm working it hard with the bucket or forks,
when I'm ready I take my 3 pound hammer and give the bottom of each pin a good rap, and lube the pins and springs she
will work as slick as can be then.
/ My Quick-Attach won't Detach... Dangit! #6
Mine does that sometimes, too. Less often if I grease the sleeves that the engagement pins ride in. For now, though, the penetrating oil/hammer treatment sounds like your best bet. Just remember to block the thing up if you need to get under it. Curl the bucket back to help get weight off the pins.
/ My Quick-Attach won't Detach... Dangit! #7
If grease, lube, good rap, cheater don't work try getting a jack between the handle and that crossbar and spreading it apart while heating the "frozen" points with a propane torch. Careful of bending things.
/ My Quick-Attach won't Detach... Dangit! #8
I hit mine with fluid film a couple times a year.
I saw this post in my email, sprayed a ton of WD-40, waited 3 minutes and clickety-clack it popped open like a charm. I had been wondering how to lube this area.
THANK YOU!!!
Be well,
David
/ My Quick-Attach won't Detach... Dangit! #10
Mine ATI and OEM Kubota, have grease fittings on the circular weldment the lock pins are in and on the pivot handles. Never had an issue, I keep them greased. I second a cheater pipe if stuck. Better than hammering on the handles.
/ My Quick-Attach won't Detach... Dangit! #11
Mine ATI and OEM Kubota, have grease fittings on the circular weldment the lock pins are in and on the pivot handles. Never had an issue, I keep them greased. I second a cheater pope if stuck. Better than hammering on the handles.
"Cheater pope", now that's a good one, force AND prayer :)
/ My Quick-Attach won't Detach... Dangit! #13
The style that Mossflowerwoods has and which I have using a lever to operate both pins at the same time
will break if you put a cheater pipe of much size on it.
/ My Quick-Attach won't Detach... Dangit! #15
Then keep it lubricated. Issue solved.
Not really it see's too much grit and dirt and dust.
And You don't have enough leverage after working it hard.
I just reached for the lever on mine and it didn't want to budge,
when I get back to dropping the forks off and putting the bucket on I'll give the
pins a good rap with a big hammer and they will work fine.
Lifting almost a ton and carrying it up a rough roadway the pins work there way in tight.
/ My Quick-Attach won't Detach... Dangit! #16
Penetrating oil and WD-40 are good for breaking stuff free but are poor lubricants in use. For pivots and such I find roller chain lube a good solution. The stuff sprays on with solvents penetrating the pivots then the solvent evaporates leaving oil behind...
/ My Quick-Attach won't Detach... Dangit! #17
If you let the pins go dry they’re impossible to move. I’ve never had any problems once I realized grease isn’t optional.
/ My Quick-Attach won't Detach... Dangit! #18
Hitting the pins from the bottom will work.
Or, put a load on the forks and they'll release easily.
/ My Quick-Attach won't Detach... Dangit! #19
Grease the pins. Happens to me all the time. So often that I've considered piecing together a video about welding repairs to my QA.
/ My Quick-Attach won't Detach... Dangit! #20
Grease grit dirt and dust on open exposed surfaces, no I don't think so.
If they were in enclosed sleeves, yes.
I've tried some of the various dry lubes without to much benefit.
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2016 John Deer 5075E (A60462)
2016 John Deer...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
