My "NEW" Tractor
/ My "NEW" Tractor
Re: My \"NEW\" Tractor
I just wanted to thank everybody here in the group. All the info and knowlege here really helped me pick a top notch yanmar. Thanks again guys!!! rccoyote
/ My "NEW" Tractor #12
on my 1802d that vavle controls the hydo fluid .. to the 3point
/ My "NEW" Tractor
Thanks Ket, I think from the replies so far that it controls hydraulic fluid to the three point. BUT I'm still not sure how to adjust it and when to adjust it or if it's dangerous to adjust it or exactly HOW or in what way it controls the 3 point. Why would i need to adjust it. The only reason that makes sense is the one about locking it in the up position to work on an attachment. I'm thinking I'm gonna leave that sucker alone until i get an english owners manual. Unless someone can tell me for sure how to use it. In great detail. Thanks guys rccoyote
/ My "NEW" Tractor #14
"Unless someone can tell me for sure how to use it. In great detail."
Here's your great detail.... It also locks it in the down position, or wherever it happens to be when you close the valve. It is called a "stop valve" for obvious reasons. It is either open or closed, no adjustment.
/ My "NEW" Tractor
Could you maybe go into a little greater detail on your great detail. What happens if i run the tractor with the valve closed? any damage to the hydraulics. Can i operate the Fel when this valve is closed?? all the hydraulics seem to run off of one pump on my tractor so i would hate to damage something expensive by messing with a valve until i know what it does in GREAT detail. Thanks normde2001. all info is very helpful. This is my first tractor so I'm being kinda gunshy with it. Even though it was a great deal it was still a good chunk o change!
rccoyote
/ My "NEW" Tractor #16
I have closed this valve on my tractor and it does stop the 3pt from moveing up or down.. I dont think it will hurt anything leaveing it closed but not positive.. I have used it when working on something on tractor(tractor Off) so it stays in position. but not when running.. I can also adjust rate or speed impliment lifts or drops with this valve.. I dont mind it coming up fast but when I set something down I like it slow so it does not slam the ground
/ My "NEW" Tractor #17
As long as you do not operate the rear hydraulics, the fluid is diverted back into the tractor and it is safe have the stop valve closed.
If you operate the three point hydraulic valve with the stop valve closed, then the fluid have no where to go. This is bad for your pump.
The exception...
There is usally a hydraulic port on the 3 point hydraulic valve. So you can connect and additional hydraulic implement instead of your three point lift cylinder that is operated from your three point valve. Once you make the connection, then by closing the stop valve, you divert the fluid to your additional implement.
/ My "NEW" Tractor
Thanks Kieth, you answered some of my concerns(most). If I understand (correct me if i'm wrong) I can tap into the rear hydraulics to add ,say a log splitter, and when i have the splitter attached , i would close this valve to operate the splitter with the tractor hydraulics. This would be great! Thanks again. I'm learnin' as i go!! rccoyote
/ My "NEW" Tractor #19
All of the Yanmars I have put remote hydraulics on used an open center valve and was tapped in series with the high side line.
/ My "NEW" Tractor #20
looks the like the knob that will control the speed at which your 3pt. will desend.
2008 Kubota M125X (A60462)
2008 Kubota M125X...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
