My new backhoe thumb
/ My new backhoe thumb #21
I don't see any significant benefit to the curve, no, RCR. Since my
current thumbs were drawn in a CAD application, putting a little curve
and some teeth in it did not cost any more when the CNC shop cut the
1/2" plates.
As for deciding on how long to make the thumb, I made my current thumbs
as long as I could without hitting the main boom at full crowd. I allowed
a little less than an inch clearance at the closest point betw the boom and
thumb.
/ My new backhoe thumb #22
rcrcomputing said:
There are times when I wish I had a horizontal piece to fit over the teeth, like when I'm reaching down the side of the dam and plucking small cedar trees. Hard to grab a tree that's only 1" diameter.
see thats what im thinking, a thumb and my grade blade at the same time. then you could pick a flea off the south end of a north bound hound with the set up
/ My new backhoe thumb #24
thumb.
doesnt that limit the size of material you can pick up? Im wanting to pick up even small rocks with mine.
if anyone can would they post some pics of the teeth on their thumbs, im trying to decide on the layout
/ My new backhoe thumb #25
I AM somewhat limited from picking up very large rocks, but if I can
not get my thumb and bkt around it, it is prob too heavy anyway. I am not
limited at the small end, as you can imagine with this photo. When my
thumb is perpendicular to the boom, the middle bkt tooth meets the end
of the thumb near its tip. If I put much more curvature in the thumb, then
long thin objects like branches or pipes would not be firmly grasped.
/ My new backhoe thumb #26
ahh your "full crowd" coment had me confused, i thought you meant when the bucket was fully curled the bucket would clear the thumb.
i plan on mounting mine where when the bucket is at 90 degrees from the dipper stick the teeth will contact each other, much like yours in the pic
/ My new backhoe thumb #27
I put a very slight curve to my thumb jaws, but teeth quite a ways up, not knowing what I'll end up grabbing with them.
You can see them folded out of the way and then how they meet the bucket teeth.
Here's how I made mine.
/ My new backhoe thumb #28
dfkrug said:
Looks fine, RCR. Simple, effective, and you got to recycle some leftovers.
My first thumb was straight, too, and the subsequent ones all had just
a slight curve. I also found that I had plenty of grip with either no teeth,
or just a few small teeth.
so from what your saying i really did not need to spend the time to make such agressive teeth on mine. how about the webing between the teeth, i noticed some have nothing and some are almost solid. Have you noticed any advantage either way? now that I have the rough in done and looking at some of the other thumbs a little closer on here i am thinking of 2 things, make it lighter and wider. light part is easy, wide part hmmmm
think im in the running for the tbn's ugly thumb contest,lol
If you want to pull t-posts, or god forbid a 4x4 with those mean teeth, you'd better do something where the bucket tooth hits the thumb teeth.
Not anymore.. YOU WIN! <giggling profusely>
/ My new backhoe thumb #30
I grabed a sandstone by the corner and it just shattered, it was awsome. lol
now im going to have to do some dental work i guess, want the thing wider, lighter, and painted
/ My new backhoe thumb #32
I enclosed the center part of my lastest thumb with steel plate because
it made the thumb stronger and it helped to hold dirt in the bkt when digging.
The thumb undergoes tremendous off-center forces when you grab things
like rocks. The wider you make the thumb, the more twisting torque it will
need to endure. If you go more than 4" wide, I would suggest using a 1"
or larger main pivot pin.
RCR also has a good point. Some jobs you have may be easier with the
thumb shaped a particular way. I found that a wide thumb tip made of plow
steel held up better than pointed mild steel. Mild steel wears fast when it
encounters lots of rocks.
Hahaha, just spit my coffee all over!!!:D :) :D
I really was giggling as I wrote it! :)
Workinallthetime, Just kidding.... Did I make you mad? I gave you a whole day to jab me back! Talk to me! Helloooo
/ My new backhoe thumb #34
lol not at all, busy day at work and soaking all this thumb talk in. Im really aiming twords a 50% redesign. I did just get home and run straight out to play with my thumb in the rock pile, ohhhh that was fun, lol.
I like the way you set yours up with the width and then the webing w/ teeth , but then the idea of the increase in pressure from side to side has me thinking.
I have the steel to do the rework, but do not have a 10" pin or even know if i can get one that long. I have some bar stock but its bearly 5/8 and i know that wont do. the dril press I have is a very bad excuse for a drill press so its the torch and the grinder. perhaps the bar stock could be the teeth hmmmm
back to the scrap pile.
i do love what the redneck think tank has to say
/ My new backhoe thumb #35
did not have time to paint it yet but here is the rework on the thumb, was to anxious to get out and try it out. went from 5" wide to 10" wide, bottom teeth drop below bh teeth, less agressive also.
works like a dream on rocks and ripping out brush
Ah man! You went and made it prettier. So, give us the lowdown between narrowor vs wider.
I'm coming to your place so we can have a backhoe show-down fight!
Forgot to ask, do you ever adjust the Top link length?
/ My new backhoe thumb #38
narrow vs wide hmm, id have to say with the wider stance it easier to grab and move the stuff while your working with it. I spent the day ripping out weed trees and moving rocks and it performed perfect. my biggest thing on the first design was the solid bottom and the way the bottom teeth were made it was dificult to grab things pusing the thumb foreward, with the open design there is less mass moving through the dirt and things flow better. I also went slightly below the teeth on the BH with the teeth on the thumb, weather or not this is good or bad is yet to be determined. i was able to use those bottom teeth many times today to help position things.
have not adjusted the "top link" at all and I have to do some adjustment on the top brakets so i can fold it out of the way. I am also have not used it with my grade blade yet to see how that works out
***> i need to mention something that I ran into today.
I was using my thumb on the side of a hill today moving sandstone, I grabed on one and rotated to the downside of the hill with the dipper stick low and straight out in order to deposite the large rock where i wanted it. As the dipper stick / bucket got to 90 degrees i felt the tractor start to go over, i droped the rock and swung back very quick and smooth to prevent me and little B from ending up on our head. Having the added weight of the rock was enough to start the motion, had this been a load of dirt I never would of had a problem.
Since this thread is about thumbs hopefully alot of people will see that by adding a thumb + a rock can put you in a situation that you would not ever be in w/o a thumb.
something to think about but i still love it !!!!!
/ My new backhoe thumb #39
I like the wider design and also that your thumb has extended length to it. I found using my thumb (which is like your redesign) works works pretty darn good at grabbing stuff. It also keeps buckets of dirt in without a complete curl, so that's why has never come off. One thing about an articulating thumb, when the hoe is completely stretched out, the thumb is also completely folded back, out of the way so I can start my dig way out there without interference. Then they come together as I curl, the bucket and thumb scooping towards each other.
/ My new backhoe thumb #40
I supose that sweet spot is just about where ever you want it to be with an articulating thumb, the static one has a very limited point of engagement for small items.
ohh and yours was alot of the inspriation for mine, lol the first one i built looked liked a 5 year old made it. I just really didint have the time for all that drill press work. have you noticed any benifit for your center teeth? I used mine today in just about every way i plan on using it and it worked great, i was going to add them but after today dont really see a reason to.
if we get another ice storm this winter i will be building one of these,
John Deere XUV825E (A61307)
John Deere XUV825E...
Reddick Crop Sprayer (A62613)
Reddick Crop...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
2012 TROXELL 200BBL CRUDE TANKER (A65643)
2012 TROXELL...
(1) 20 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
