My little wagon
/ My little wagon #1
joelaudi
Cheshire CT
1960 Case 430, 1947 Ford 8N, 1942 Ford 9N [not running], 5252 Cub Cadet to cut the lawn, John deere 140 , Sears SS12, Crafsman 5000GT, and a Gravley 816 which may be the most rugged tractor that I have ever seen.
Here is a four wheel wagon that I just finished building. It is something that I wanted but really don't need. It is made from a selection of automotive parts like VW spindles and hubs, Honda rims, and Audi tie-rod ends. It measures 10 1/2 feet long and 5 1/2 wide and rolls on 14 inch tires. The body is all rough cut oak with boiled linseed oil on the top surface and used motor oil on the bottom. I painted it Ford red on the running gear and the wheel are Ford grey to match my 8N. I tried to size it so I can pull it with either the 8N or my Cub Cadet 5252. It follows quite well as there is bronze bushing and bearings through out. I think it will hold about 4000 LBS but don't know.
/ My little wagon #2
Wow, that's sweet! Nice job. Something I've been wanting, but no real justification. You did a great job, thanks for posting!
/ My little wagon #3
Good Evenin Joe,
Beautiful job !!! The only thing that could be better is if it was filled with firewood ! ;) Sharp lookin trailer ! :)
/ My little wagon #4
That is a great looking trailer.. IF you feel the need to make another, Ill be more than happy to take it off your hands.. LOL
BTW - those are some fancy looking wheels you have on it.. Did you consider spinners?? LOL
Brian
/ My little wagon #7
Joe, nice job on the wagon! Do you have any pics of various stage of fabrication? I like the idea that you built your own running gear. Some folks around here have built their own from torsion axles and use a spindle to fabricate a fifth wheel to turn the front axle. These are used primarily for wagons being pulled by teams of animals. Using the axles they are able to have brakes as well. We on the other hand have an old converted farm wagon that's set up a lot like yours. We did go back and retrofit a set of rear disc brakes to replace the old hand brake. Of course I'm talking of another use for a wagon entirely. Again, great job!
/ My little wagon
Sorry, I don't really have photos during the build. This was something that just took shape. My dad was a machinist by trade and had a bridgeport miller and lathe in his garage. I since have the equipment in my home now and have been finding things to make to hone my skills. What better way than to build something useful. The main frame is 2x4x1/8 steel tubing and the front knuckles have 1 1/8 king pins. Here is a picture that may show the front better.
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
72in. Fine High Side Skeleton Skid Steer Bucket (A65640)
72in. Fine High...
2015 Hitachi ZX75US Midi Excavator (A64553)
2015 Hitachi...
1999 International 5000 SFA Day Cab Truck, VIN # 1HTTWADR6XJ004085 (A65563)
1999 International...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
