My Homemade Flail Mower
   / My Homemade Flail Mower #1
Teigrek
Lower Silesia (Poland)
Yanmar YM1810D
   / My Homemade Flail Mower #2
Nice job. You should be proud. What kind of cutters did you use. The '' Y " kind?
   / My Homemade Flail Mower #3
Very impressive build. It simply amazes me to see some of the projects that pop up on this forum. Well done!
Joe
Thanks for the kind words:)
Yes, these are the cutters, "Y". Initially, the rotor had a vibration, but we gave it to the balancing service, and is now very well even with 1000rpm PTO!
But it is still a small problem to solve: Cuts of plants wrapping around the rotor slots -in narrowing next to bearings. I will have to installed there some type of cover.
MIchał
   / My Homemade Flail Mower #6
MIchał
A steel ring larger than the bearing with a plate on one side, similar to a cup welded to the rotor and spaced as close as you can to the side plate might help get rid of some of the grass wrapping around the bearing.
David from jax
   / My Homemade Flail Mower #7
Very nice. I knew Porsche made tractors but I never saw a Ferrari tractor.
   / My Homemade Flail Mower #8
great build
I'm glad you like it :)
I already solved the problem with the grass wrapping around the bearing.
I have seen in Italy a real Ferrari tractors. It's a different company than the cars Ferrari, but called the same. They produce a green compact tractors :)
   / My Homemade Flail Mower #10
Do you have it made ​​by a draft, can you tell us a bit more detail. Because I want to make one of these. Greetings from Serbia!
EZ GO EXPRSS S4 EFI GAS GOLF CART (A51247)
EZ GO EXPRSS S4...
2017 POLARIS RANGER 500 EFI UTV (A51247)
2017 POLARIS...
UNUSED MOWER KING ECSSCT72-72" HYD TRENCHER (A51248)
UNUSED MOWER KING...
Hustler Raptor SD Zero Turn Mower (A51573)
Hustler Raptor SD...
2022 JOHN DEERE 5075E LOT IDENTIFIER 30 (A53084)
2022 JOHN DEERE...
