My homemade crane for erecting timberframe and hoisting timberframe trusses
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #1
TerryMcQ
Kubota B2320
I had to design it to tilt to fit under 10 foot high doors to metal polebarn so I could keep it out of the weather when not in use. I may never need it again but it was cheaper than renting or hiring.
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #2
Pretty cool!
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #3
Interesting.
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #4
Where there is a will there is a way! great job!
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #5
Yours is nice. Here is one I made for FEL on my M5700. Use to put up floor I beams , floor decking , posts , etc.
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #6
What size material did you use for the arm, I'm needing to build something like that.
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #7
<img src="http://www.tractorbynet.com/forums/files/customization/403829-my-homemade-crane-erecting-timberframe-img_0610_2-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/403830-my-homemade-crane-erecting-timberframe-img_0635_2-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/403831-my-homemade-crane-erecting-timberframe-img_0353-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/403832-my-homemade-crane-erecting-timberframe-img_0354-jpg"/>
Very creative!
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #8
Both are neat!
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #9
My dad built one out of about 2" pipe. Worked on the 3 point of a jubilee. Just a piece of pipe with a piece of angle welded to the bottom for the lift arms and a bracket welded to it for the top link. Lifted pine tear poles about 20' for a hay barn. Used a rope block hooked in the top,and a man could carry it ballinced on his shoulder.
Do you know where I can get a pin on to quick attach converter for my L304 front end loader? I've seen them for begged kubota FELs but don't know what will interchange. I need to transplant a bunch of evergreens with a tree spade or tree scoop but they only make them for quick attach front end loaders. I don't want to use 3-pint attachment because I don't want to back up and look over shoulder for every tree to dig.
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #11
I like it!!! What size tubing did you use for the A frame?
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #12
Do you mean an SSQA adapter that will pin on to the LA304 ?
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
(13) WOOD PALLETS (A60432)
(13) WOOD PALLETS...
Case SV280B (A60462)
30in. Forks and Frame Skid Steer Attachment (A59228)
30in. Forks and...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
FORD 8630 TRACTOR (A60430)
FORD 8630 TRACTOR...
