My homemade crane for erecting timberframe and hoisting timberframe trusses
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #1
TerryMcQ
Kubota B2320
I had to design it to tilt to fit under 10 foot high doors to metal polebarn so I could keep it out of the weather when not in use. I may never need it again but it was cheaper than renting or hiring.
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #2
Pretty cool!
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #3
Interesting.
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #4
Where there is a will there is a way! great job!
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #5
Yours is nice. Here is one I made for FEL on my M5700. Use to put up floor I beams , floor decking , posts , etc.
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #6
What size material did you use for the arm, I'm needing to build something like that.
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #7
<img src="http://www.tractorbynet.com/forums/files/customization/403829-my-homemade-crane-erecting-timberframe-img_0610_2-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/403830-my-homemade-crane-erecting-timberframe-img_0635_2-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/403831-my-homemade-crane-erecting-timberframe-img_0353-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/403832-my-homemade-crane-erecting-timberframe-img_0354-jpg"/>
Very creative!
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #8
Both are neat!
   / My homemade crane for erecting timberframe and hoisting timberframe trusses #9
My dad built one out of about 2" pipe. Worked on the 3 point of a jubilee. Just a piece of pipe with a piece of angle welded to the bottom for the lift arms and a bracket welded to it for the top link. Lifted pine tear poles about 20' for a hay barn. Used a rope block hooked in the top,and a man could carry it ballinced on his shoulder.
Do you know where I can get a pin on to quick attach converter for my L304 front end loader? I've seen them for begged kubota FELs but don't know what will interchange. I need to transplant a bunch of evergreens with a tree spade or tree scoop but they only make them for quick attach front end loaders. I don't want to use 3-pint attachment because I don't want to back up and look over shoulder for every tree to dig.
case 370 glass door never installed (A56435)
case 370 glass...
3650 (A47477)
3650 (A47477)
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
