My Friend, Arrabil
   / My Friend, Arrabil #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Arribil stopped by today to help me reverse the rear tires on my 4400. Well, he did most of the work, I operated the floor jack.
I'd like to thank Arrabil for his work...and his knowledge.
Good man, My friend!!! And thanks again!
   / My Friend, Arrabil #2
Nice to have those good friends,they sure do add to our lives don,t they?:thumbsup:Dave
   / My Friend, Arrabil #3
Roy, you are very welcome!
I got to drive a Sync Reverser for the first time too. Just like a stick shift.
You did a fine job at it too!
Well, I'll pick up that wheel bolt and borrow a tap to chase the thread (for all you other TBNers, looks like when the tires were replaced one wheel bolt had been slightly buggered). Then loosen and properly retorque the bolts.
You know, Arribil...I should have had my "bull" hat on...most these guys don't believe it's real!
   / My Friend, Arrabil #5
Part of tractoring..friendship,just can't beat it. :)
   / My Friend, Arrabil #6
When I put wheel spacers on my 110; I told my buddy I was gonna watch a playoff game on the dish... he came right over! :D (Those tires and wheels are HEAVY!!)
'Course we got to watch most of the game! Things go a whole lot faster with another set of hands and a stronger back! :thumbsup:
Nothin' like good friends, cold beer and sandwiches and tractor projects!
AKfish
   / My Friend, Arrabil #7
Always good to hear stories like this! Thanks for sharing Roy. I met a fellow TBNer (6dogs) also a few weeks ago to look at a used tractor he was interested in-he ended up buying it for a song and I have a new friend also.
   / My Friend, Arrabil #8
It really is nice to see virtual friendships turn into real ones:thumbsup:
Greg
   / My Friend, Arrabil #9
Roy, it just occurred to me... we should have but that bolt in from the other side. Probably would have straightened the threads out. Doesn't matter now that you got it fixed but maybe one of us will remember if there is a next time.
Tried that...sent you a PM on that (and some other stuff).
So everyone else isn't curious...
The first few threads were buggered up (probably from airgunning the wheel bolts) and we couldn't get one bolt in.
I bought a couple rear wheel bolts and borrowed a 14mm x 1.5 pitch tap from work. I chased the threads, but the first few were a write off. No good way to repair that kind of thing (other then drilling it out and installing a helicoil or other type insert).
When a hole is threaded, the machinist drills with the appropriately sized drill, then chamfers the hole. Then chamfer provides an easy entry for both the tap and, ultimately, the bolt or screw.
The exit side of a tapped through hole isn't chamfered so the lead in for the first thread isn't there. The last thread may not be perfect form, so a bolt may not enter easily, or at all (which is what I found when I tried).
I'm just glad not all the threads were buggered up. Airgunning is a great way to remove bolts, not so hot for installing them (it's ok to run the bolts in, but not tight...use a torque wrench for that). This is especially applicable for aluminum wheels, btw.
2001 Great Plains 3N-3010P-4875 Grain Drill (A50657)
2001 Great Plains...
Honda Foreman ATV (A50860)
Honda Foreman ATV...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
71057 (A49346)
71057 (A49346)
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
Misc. Electronics (A50860)
Misc. Electronics...
