My first stump
/ My first stump #11
Brad,
You don't really need the box for smoothing out that area. Yes it might make it easier--after learning how to use it but for a small area like that you could "make do" with the FEL bucket and toothbar you already have. But if you had a hydraulic top-link with the box it becomes a totally different story.
Since you don't yet have the box and hydraulic top-link --yet, use your bucket with the toothbar. By varying the amount you tilt the bucket down (forward) the teeth will be protruding more or less. When the bucket is flat the teeth don't protrude, when the teeth are pointing straight down they protrude 8ish inches.
When smoothing out an area, after it has had fill dumped, I start with the bucket flat, apply enough down pressure to almost lift the front wheels off the ground, then tilt the bucket enough to make the teeth protrude around 6", then drag backwards. This action acts like a rake pulling large amounts of dirt but allowing some dirt to go through the teeth, thus creating a smoothing action. I keep repeating the same action from different directions gradually reducing the amount the teeth protrude until the bucket is flat or slightly rolled back. If you want to move dirt without allowing it to fall through the teeth you just roll the bucket backwards, apply all your down pressure and drag backwards. Of course the bucket can also be used forwards to pickup and move larger amounts to proper area and then use the backdragging operation.
Despite the fact that I have a box I usually end up using the above method for small areas, its faster and the results are just as good. For larger areas where your "run" is longer the box seems to work best for me.
Learned this technique from watching skidsteer operators. Its amazing how fast an area can be leveled and smoothed. Works real well for distributing gravel on a driveway, even when the gravel is "tail-gated".
What are the opinions of others? When do you use the box vs. the FEL?
/ My first stump
Dave,
Thanks for the advice.
I have used that technique before with some success. I can level an area pretty well, but can't get a real smooth finish. The toothbar doesn't make it easy to do the final passes smooth. I've read on here about using the heel of the bucket instead, but there's a fine line before the quick-detach brackets on the bucket start digging in. That's the only drawback I can see on the QD bucket.
I could take the toothbar off, but so far I seem to use it a lot.
So my next purchase will probably be the box blade. I've already got a hydraulic top link but it isn't doing me much good right now.
I agree about a good skid steer operator being able to grade an area quickly, that was the only thing the contractor used to finish our yard before we moved in.
/ My first stump #13
Looks like your life got a lot easier /w3tcompact/icons/smile.gif and may the rest of your project be a snap. /w3tcompact/icons/wink.gif
/ My first stump #14
now u done it, now the wife knows it ain't work. and she will take over that tractor also/w3tcompact/icons/grin.gif
/ My first stump #15
Brad, the problem with having a great tractor is you suddenly have more jobs because you have the tools to do them. BTW - Aren't you glad you have 4WD? I bet your tractor got a little light in the rear with that stump on your forks. It's also good you have fairly level land. Good job!/w3tcompact/icons/smile.gif
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2022 Behnke Trailer (A55973)
2022 Behnke...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
Toro (A56857)
Toro (A56857)
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
