My first stump
/ My first stump #1
BKColeman
Virginia
TC 40D w/ SuperSteer
I used my TC 40D to remove a my first stump last night. I worked on it for about a week off and on with the loader and toothbar breaking all of the roots loose and rocking it loose. I couldn't get it picked up with the loader so I tried dragging it with a chain, but that tore up the yard too bad. I didn't think the forks could lift it either, but they did.
Attached is a picture of it on its way to the burn pile. If anyone is interested, a few more pics can be found <A target="_blank" HREF=http://www.pbase.com/bkcoleman/stump>here</A>.
--Brad
/ My first stump
My wife thought it looked like fun driving the stump to the burn pile so she decided to try. She came and got a load of old logs and hauled them off.
What a wife! /w3tcompact/icons/love.gif
--Brad
/ My first stump #3
No doubt about it, Brad. That's a stump!!!
That's a gorgeous blue machine, too. You guys with the big horsepower make me so jealous. I like your photo page -- looks like some twilight pictures, which adds to the surrealistic effect.
Thanks for sharing.
/ My first stump #4
Brad,
My question is. Did your wife turn the tractor back over to you, or did she have so much fun that she decided to keep it for herself ? /w3tcompact/icons/laugh.gif
Seat time is very contagius. You may have created a monster. /w3tcompact/icons/laugh.gif
/ My first stump #5
Brad,
That's an impressive stump. How long did it take to fill in the hole? Is that extra piece on your bucket a 4in1 thing?
/ My first stump #6
Fill us <font color=orange>orange</font color=orange> and <font color=green>green</font color=green> guys in on your machine. What is the HP at PTO etc? Nice work by the way!
/ My first stump
Harv,
It was twilight. I hadn't planned to move the stump because it was late, but it looked like fun so I got wrapped up. I had to work to get the pictures to come out decent at all.
--Brad
/ My first stump
<font color=blue>You may have created a monster. </font color=blue>
She had already taken over my Craftsman riding mower. And no, she didn't turn it back over to me. /w3tcompact/icons/crazy.gif She put it to bed for the night. I had to walk all the way back to the house as she drove off and left me. /w3tcompact/icons/sad.gif
--Brad
/ My first stump
Thanks Grant, it didn't take long at all to fill in the hole. The stump was right across the driveway. The builder (we just moved in December) had piled up some dirt from the excavation beside the stump so I just pushed it in. I've still got some cleanup to do though. But it is raining today. /w3tcompact/icons/sad.gif
I don't have my bucket on in the picture, I've got a set of forks on. See attachment.
/ My first stump
Thanks Tony.
My tractor is a TC 40D with SuperSteer. 40 HP (33.2 PTO HP). I've got a quick-detach HD bucket w/ toothbar that I used to dig it out and the qd forks to carry it. It's got 3 rear remotes w/ hydraulic top and tilt cylinders, but I don't have a box blade (yet /w3tcompact/icons/sad.gif), which I need to smooth out where the stump was.
--Brad
/ My first stump #11
Brad,
You don't really need the box for smoothing out that area. Yes it might make it easier--after learning how to use it but for a small area like that you could "make do" with the FEL bucket and toothbar you already have. But if you had a hydraulic top-link with the box it becomes a totally different story.
Since you don't yet have the box and hydraulic top-link --yet, use your bucket with the toothbar. By varying the amount you tilt the bucket down (forward) the teeth will be protruding more or less. When the bucket is flat the teeth don't protrude, when the teeth are pointing straight down they protrude 8ish inches.
When smoothing out an area, after it has had fill dumped, I start with the bucket flat, apply enough down pressure to almost lift the front wheels off the ground, then tilt the bucket enough to make the teeth protrude around 6", then drag backwards. This action acts like a rake pulling large amounts of dirt but allowing some dirt to go through the teeth, thus creating a smoothing action. I keep repeating the same action from different directions gradually reducing the amount the teeth protrude until the bucket is flat or slightly rolled back. If you want to move dirt without allowing it to fall through the teeth you just roll the bucket backwards, apply all your down pressure and drag backwards. Of course the bucket can also be used forwards to pickup and move larger amounts to proper area and then use the backdragging operation.
Despite the fact that I have a box I usually end up using the above method for small areas, its faster and the results are just as good. For larger areas where your "run" is longer the box seems to work best for me.
Learned this technique from watching skidsteer operators. Its amazing how fast an area can be leveled and smoothed. Works real well for distributing gravel on a driveway, even when the gravel is "tail-gated".
What are the opinions of others? When do you use the box vs. the FEL?
/ My first stump
Dave,
Thanks for the advice.
I have used that technique before with some success. I can level an area pretty well, but can't get a real smooth finish. The toothbar doesn't make it easy to do the final passes smooth. I've read on here about using the heel of the bucket instead, but there's a fine line before the quick-detach brackets on the bucket start digging in. That's the only drawback I can see on the QD bucket.
I could take the toothbar off, but so far I seem to use it a lot.
So my next purchase will probably be the box blade. I've already got a hydraulic top link but it isn't doing me much good right now.
I agree about a good skid steer operator being able to grade an area quickly, that was the only thing the contractor used to finish our yard before we moved in.
/ My first stump #13
Looks like your life got a lot easier /w3tcompact/icons/smile.gif and may the rest of your project be a snap. /w3tcompact/icons/wink.gif
/ My first stump #14
now u done it, now the wife knows it ain't work. and she will take over that tractor also/w3tcompact/icons/grin.gif
/ My first stump #15
Brad, the problem with having a great tractor is you suddenly have more jobs because you have the tools to do them. BTW - Aren't you glad you have 4WD? I bet your tractor got a little light in the rear with that stump on your forks. It's also good you have fairly level land. Good job!/w3tcompact/icons/smile.gif
