Price Check My first post...
/ My first post... #1
Burgie
Falcon, Colorado
Kubota B2620HST w/ FEL,
Greetings folks...
OK...so this is my first post and I am curious to see what a new B2620HST will cost? The Kubota price is $18,245...see below image of configuration...but I am not educated as to the margin on these tractors (for any manufacturer).
I have no real timeline for a purchase but rather am collecting information so I am armed with better data!!!
Thanks much, in advance...
Burgie
/ My first post... #2
That's the way to do it. The more you research the better your choice is. Welcome to TBN. A good deal would be 15% off list.:thumbsup:
/ My first post... #4
Welcome to TBN.What are the attachments and what do you want to use the tractor for?
/ My first post... #5
Welcome from sunny and HUMID central Florida!
I am sure you'll find the folks here very helpful in your search.
:welcome:
/ My first post...
In a nutshell, I have a little over 1/2 acre of land and I have totally renovated the property in front of the house. This has involved tons of manual labor removing all sod, regrading the property and xeriscaping. Time to do the sides and back and my friend is letting me use her B2320HST. Boy I love that little tractor and now want to get one. The initial purchase will be just the tractor, FEL and ballast box but afterwards I want to get a rototiller and box scraper. I will use those as negotiating tools to lower the cost of the tractor or give me a darn good discount on the implements and I'll buy them at the time of purchase ...
/ My first post... #7
If you love the B2320 then you will love the B2620 as they are basically the same tractors.The 2620 has three more horsepower and twelve more foot-pounds of torque.It also has a stronger loader although the 2320 can be ordered with the same loader.As for pricing it varies with regions and definitely between countries.I just recently bought a B2620 with a FEL,weight box,and 54 inch mower deck.I live in Canada so we generally pay more than the US.My price was 19500 before trade in or taxes. You didn't mention a mower deck so you could take about 2500 off for that which would be 17000 for the package you are looking at.
/ My first post... #8
Welcome! That 2620 is a neat little machine. Here's a suggestion to think about:
Many owners do not have a rear weight ballast box... they save the expense and simply use one of the attachments, typically a box blade, which you're planning to buy anyhow. It's reasonably heavy and tucks in behind the tractor pretty well. You can even hang extra weight on it if needed. We've done that with both of our tractors since the box blade is typically used for the same dirt moving the FEL is used for. Nothing wrong with a ballast box, but unless you need to work in really confined spaces, in many situations the box blade is a more functional substitute. And, since you undoubtedly see a snowflake or two out your way, putting the money a ballast box costs into a scraper blade would give a better snow moving setup than just the FEL and ballast box. The combination of box and scraper blades to go with the FEL will make your 2620 a very effective tool for moving dirt, driveway maintenance and snow removal. You'll want to add fluid in the rear tires, of course, for added traction.
/ My first post... #9
forget the weight box, and just get the box blade and be ahead of the game. you will never look back, until your boxing your way to a level property
/ My first post... #10
Welcome! Ditto on the box scraper and not the weight box.
/ My first post... #11
Agree on the box blade for ballast, Heavier the better, I'd say I have a medium grade 60" box blade and it weighs about 350 lbs, I like the way the tractor handles and operates when using the loader with the box blade on, though in the woods you have to remember it's back there. I keep smacking the trees with it :) .
Locally here the B2620 sells for $12,200 and the loader was $3200 . the local dealer fills the rears, no extra charge with the loader.
hope this helps a little.
/ My first post... #12
Those really aren't negotiating tools. They won't go below a set point regardless of what you buy along with the tractor. Also, in many cases, big dealers are on the high end of price for implements, which are purchased from suppliers who paint them the requested color. In short, you can buy the same, or better, implement from another source and pay less. Yes, the dealer might knock some off their list price if you buy them with a tractor, but that really won't be saving you anything. I'd get a hard quote from them for each implement, then compare from other sources, including online places like Everything Attachments.
A more effective way to get them to come down to their real bottom dollar is to have hard quotes in hand from other manufacturers/dealers. Losing a sale to another brand and dealer means they expect to lose future business as well. If you want to magnify the difference, get a quote for something like an LS G3033H and Kioti CK30H. You'll find that they have a lot more capability, are comparable in quality, and cost around the same amount as the Kubota. That's the sort of bargaining chip that can make a dealer work on their price.
/ My first post... #13
Good advice here...get several quotes and make them work for your business. Don't get stuck on one brand or one tractor because you used one and liked it.. You would have liked a lot of tractors if you had been presented with them. Not saying your choice is bad, because it isn't, just that you should keep an open mind and do a lot of comparisons. I have 2 implements from Everything Attachments, and Like them both. Plus you should watch all of the video's.
Tractor and Skid Steer Attachment Videos
James K0UA
/ My first post...
Great advice and recommendations from everyone!!! Thanks very much...
Sorry I've been off-line, it's been a nuts week at work :)
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
(APPROX.9) UNUSED KJ GALVANIZED WELDED WIRE MESH (A62131)
(APPROX.9) UNUSED...
Gradall no crank no start (A61568)
Gradall no crank...
2006 Mitsubishi Endeavor SUV (A61569)
2006 Mitsubishi...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
