my dump cart
/ my dump cart #41
Nice build banditbooker. Would like a good dump trailer.
/ my dump cart #42
I have been trying to search on the internet, but can't find anything. I might not be using the correct search wording. But I was wondering if anyone has built a dump trailer using a scissor jack like the picture below.
Someone had a old 30ish Dodge truck for sale in my town recently, and the dump bed used a jack like the above, but of course it was much larger in size. I happen to have a very long acme threaded rod and nut,, you would probably have to custom make the jack so it would raise high enough. I thought the idea was a good one, and the setup I looked at on the truck looked like it was original/very old. You could even put a motor and gearbox on it if you wanted to.
/ my dump cart #43
Thanks to this thread, I've been researching building my own trailer when I stumbled across this.
Sure Trac |
$1,800
I was up to $500 with axles, rims, tires and springs and had not even figured in the steel yet.
I wanted to make my own because I wanted it small enough to pull behind the tractor and yet still street legal.
I don't know that I could beat this
/ my dump cart #44
The tires are perfect. They keep the deck low,looks really nice to load.
/ my dump cart #45
I bought a jack like that with an electric motor for my lil dump trailer, long story short the **** things have no power when there all the way down (physics) they gain lift power towards as they go up, anyhow I messed up the plastic gears inside don't know where I can get replacements I do have pics of my setup and have modified my pivot points to take some weight off the jack, so if anyone knows where I can get replacement gears for these Chinese junkers chirp in
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2016 16ft. C and S Lawhon 2.5 Ton Pipe Top T/A Utility Trailer (A60352)
2016 16ft. C and S...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
