My Container Barn
   / My Container Barn
The only real ugly spot was lining up the roof line along the top of the containers. They are a long way from being flat. I placed a straight edge across the span and built up supports the length of the containers to hold up the roof and act as purlins. I figure with enough liquid nails and the weight of the roof, it wouldn't go anywhere.
   / My Container Barn
The panels go on really quick with nice results. I only put in about half the screws I need to get as much done before the weather changed. This section is a 1/12 pitch 11 feet, 9 inches wide by 41 feet long.
A buddy with years of experience helped me installing the roof panels. A good tip is to clamp two 100 foot tapes to the beginning panels and measure each one you install to keep them lined up.
I was really amazed how the panels want to work apart. An eighth on an inch isn't much, but over a distance it really adds up.
Both roof lines lined up purfect using this technique with no fudging needed at the end.
   / My Container Barn
Half the roof is on and the weather is changing quickly! That's me on top after I put in the last of the screws for the day.
I really hate heights, but with the first panel in, I was able to funtion without too much trouble. I wore my sneakers, which allowed me to walk up and down the panels easily.
The pitch on the high side is 6/12 and just about the maximum for walking up and down. Length of these panels are 13'6" for a 41' run.
   / My Container Barn
This is another view of my post hole digger that I hung from the rafters. I doubled up a pair of 2x6's with half inch plywood glued in between.
Now it's under a roof and should stay nice a dry.
   / My Container Barn
Between the rain, I managed to get the other side of the roof on.
My free help didn't show up, so I did this side by myself. It took a full day and about three hours yesterday.
The toughest part was climbing up and down the ladders getting the panels. A real suprise came when I tried to climb up the steep part after getting some panels pre-positioned. My shoes had dirt on them and my traction was non-existant. One step up and a quick slide down! No injuries, just surprised how quickly my footing was lost.
   / My Container Barn
This is a view of the skylights from the inside.
The gap in the middle is where the roof vent is going to go. I'll need a hand with it due to its weight.
   / My Container Barn
The roof vent is in the crate in front.
This side faces North and doesn't have any skylights.
I still need to install the metal trim and finish painting the wood trim.
I'm pricing doors and will order a roll up door this week. Prices are all over the place.
Main door size is 12 feet wide and 10 feet tall after a concrete floor is poured. I'll build up the base rock to eliminate the gap under the door in the mean time.
   / My Container Barn #48
Eddie,
I don't understand why you need a roof vent... With the size of the gap between panels on each side of the roof you can cover it with "ridge-row" and have plenty of ventilation. The ridge I've used was ordered from the metal vendor in 10' lengths and I think 12" on each side of the V. It would certainly be easier to install, and probably a lot cheaper.
   / My Container Barn
You're right about the ridge vent. I was thinking the vent would be better for long term and allow me the option of closing and opening it if I ever wanted to. It might just be a waste of $200. One day I'd like to have a concrete floor, insulation and heating for working on projects when the weather is real bad. I figured I could close this vent and keep it warm inside.
DOOSAN DL250 LOADER (A51242)
DOOSAN DL250...
2004 Dodge Ram 1500 4x4 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
2003 Honda Element SUV (A50324)
2003 Honda Element...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
71060 (A49346)
71060 (A49346)
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
