My Bush Hogging experience
/ My Bush Hogging experience #1
RollTideRam
Hartselle, Alabama
Kioti DK 4710 Cab
I have been cutting grass at the small plant where my wife works. They asked me to bring my tractor and grapple one day to retrieve a few 55 gallon drums out in their field. A passerby saw my tractor and wanted me to price hogging 5 acres. I did, and waited to see if he wanted me or not before I bought a rotary cutter. A month later he called, and I got the last Deere lx5 my dealer had for cost. I cut his land and thought I learned alot for my first time. I learned I needed a suspension seat so I could mow faster than 3mph. Today I went to move some gravel for my wifes work, and they saw the bush hog and wanted me to cut some for them. This field looks to be 20 acres, way more than I want to cut. They said cut what you can in 4 hours just to make the place look better. I learned a whole lot more on my second outing.
1. You can kill the tractor engine going through deep ruts and cutting dirt.
2. Watch out for stray concrete chunks. I hit one when I looked at the train going by.
3. A tire and wheel can be hid in tall grass. This will kill the engine also. I thought I had my bucket low enough.
4. I don't know what flying beast stung me, but 5 hours later it still hurts.
5. Deep rut make you go real slow, and wearing seat belt real tight, helps.
6. Tall overgrowth can hide a deep hole very well.
7. Try to talk to the man that did this job last, since he works at said place, he might give better insight than the guy that is paying.
8. I need a bigger tractor
9. I can drink more water in four hours than I thought. Carry more water.
All this typing took my mind off of the "bee stings" JC
/ My Bush Hogging experience #2
WOW... You have probably learned more in that 4 or so hours of seat time than you would get in months of TBN reading.. LOL
Nothing quite like experience as a learning lesson..
Good luck and most of all - Remember to try and have fun... :)
brian
/ My Bush Hogging experience #3
RollTideRam:
Real seat time accelerates the learning curve :eek:! "You did good" :D. Apparently you are operating safely and well :). Good luck and stay on your seat. Keep the posts coming- Jay
/ My Bush Hogging experience #4
Sounds like you had a bunch of fun. I did a new field this past weekend and I will tell you that a suspension seat does make a big diference.
About the bees. See them all the time, by the way the tractor will not out run them I have tried. I use to get stung every year when I did my brother in laws's field. Finally got smart after the third year. Marked the nest in the fall, stayed away from in the next year when I mowed. Did help a little but I still got stung.
You do have a distinct advantage living down south. That is once you cut a field and clear and debris or rocks you are kinda safe next time around. Up north we grow rocks. You can pick up every stray rock you can see and hit and the field will be clear when you leave. But next year be prepared there will be more. They just keep growing and growing.
/ My Bush Hogging experience #6
I am curious :confused:
Do you still have an operational Tractor and Cutter, or they both in the shop getting repaired after your learning experience ??
Dan
/ My Bush Hogging experience #7
Did you break any shear bolts or slip the clutch on the cutter in your mowing experiences? Normally they break or slip before you stall the engine out?
/ My Bush Hogging experience #8
Those are the exact same reasons I quit mowing for $$$ years ago.
/ My Bush Hogging experience #10
JC
I was using an ancient (relatively speaking) MF with a 5' going through 10' bushes. Now using a TN70 with 8' going through 10' weeds and bushes (the suspension seat is much nicer than the previous mostly unsprung seat! Legs still get shaken up though). I'm starting to think 90hp+ with a batwing would be nice.... and here I thought it would be a at least a few years before the "futility" set in.
Don't think you can have too much horsepower.
/ My Bush Hogging experience #11
"1. You can kill the tractor engine going through deep ruts and cutting dirt.
8. I need a bigger tractor...."
A point to gleaned from your post is that many land owners don't always know what is on their property. Many a person will tell you it's fine and clean and no problems.......and then you run over the old tire rim, cistern lip, t-post or discarded wire roll hiding amongst the weeds.
Talking to the guy who worked it last pleads a question or two: Can you even figure out who that was and why aren't they still doing it now?
/ My Bush Hogging experience #12
The tires stall the engine because the blade's energy is absorbed by the tire instead of hitting it and bouncing off it. A discarded roll of carpet does the same thing, unless it has been in the weather for a while, then it also wraps itself around the blades, making a big mess. The concrete you hit probably didn't stall the engine but it did make a heck of a lot of noise. They have been known to become missles and break out windows nearby. Be careful!!
Around here it is yellow jackets, not bees that give you fits, and they hurt a lot more then any bee I have ever been stung by. Two nests last year. One I took care of around midnight, all wrapped up in protective gear with some 7 dust. The other is still waiting.
More horsepower is great, along with a large cooler.
David from jax
/ My Bush Hogging experience #13
sandman2234:
The non-petrochemical/poisonous method to take out ground dwelling yellowjacket hornet nests is to place a clear glass/plastic bowl over their hive hole at night they can't figure how to get out and eventually starve. It has to be securely placed or they will tunnel out. I prefer pyrotechnics :D!. That really works and the element of risk adds to the excitement :). Jay
/ My Bush Hogging experience #14
Mornin RollTideRam,
Very interesting post ! ;) I was going to post, why are you using such a small tractor to do that type of work, I guess I dont know my JD numbers vert well, just took a look in tractor data and thats a larger tractor your using ! ;) Thanks for posting to remind myself why I dont want to mow 20 acre fields with a 5 ft mower ! :) Hope the stings go away soon ! ;)
/ My Bush Hogging experience #15
Very informative story, thanks for sharing.
Now I'd like to know from all the guys that are doing bush hogging, (or used to).
What do (did) you charge? and by the hour or acre?
Did you adjust your rates depending on condition of the ground?
I think it would be very helpful to fellow TBN ers to know what rates are being charged around the country for different jobs.
/ My Bush Hogging experience #16
I use an LX5 and do 5 - 20 acre places.
I charge $25 - $45/acre. I usually mow in 2Hi at 540PTo
If the land is pastureland that is maintained (grazed, shredded regularly) then that's $25. You add 110 degrees out and the price goes up - mesquites, think weeds rough terrain - price goes up.
Wit all this rain - I've got about 40 acres piled up - so once it stops...I'll be busy....Make sure you set your shredder up correctly, I shredded for a whole year until I got it right. Biggest think I learned this year, is to back ff the throttle when making tight turns - saves a lot of time by making good corners and not overdirving the steering capability - if you turn too fast, your turn will be wider. Also, unlatch your brakes and use the right pedal to make a sharper right turn.
I also remiove my bucket so I can see better - and keep an eye on the uncut portion next to you for stumps, logs, etc.
/ My Bush Hogging experience #17
This was about 15 years ago, but at that time I charged $25/acre and I stayed busy. It was a side profession from the police department.
After cutting numerous fields and lots where the owners stated that everything was clear of any problems, there was always stumps, old discarded lawn mowers, chunks of concrete, etc., to be found; tearing my equipment to pieces.
What made my decision to quit was when I turned my tractor over, with me still hanging on for the ride, in a washed out swell(sp), big enough for a cow to hide in. The owner had not cut the land in about 10 years; again stating everything was flat and not a problem. You couldn't have pulled a greasy string out of............., you get the idea.
/ My Bush Hogging experience #18
Morning Tact,
Interesting post ! I know alot of us have used the FEL to detect things out in the field, but what you forget is that, a dip or hole can be disastrous especially on a slope !!!
/ My Bush Hogging experience #19
Morning Scott!
Back then my Ford 3000 didn't have a FEL, wished it did at the time. That big hole was actually what appeared to be in a flat field. The weeds had grown so tall that it covered the ditch.
/ My Bush Hogging experience #20
I never thought about having too big a tractor for wide open spaces but it seems a plus for a smaller tractor in the fact that you have to slow down to keep from overloading the mower. That gives you more time to watch what is just ahead of the tractor before it gets to it. Also computes to a narrower mower so that gives you less area to watch at the same time. Maybe I need to start looking for a smaller tractor??
Just a thought for you smaller tractor owners.
David from jax
2007 MACK CXP613 (INOPERABLE) (A63569)
2007 MACK CXP613...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2012 Ford Explorer SUV (A61574)
2012 Ford Explorer...
Kubota L175 Tractor (A62613)
Kubota L175...
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
