My 425 fan failed!!
   / My 425 fan failed!! #81
On my 422 the switch is set at 120 deg F. An hour seems like more than enough time to turn on the fan. Is the thermal switch in good physical contact (not loose) with the block it is mounted to? Is it clean between these two services. I know that the fluid for the wheel circuits does not go through the hydraulic cooler. If you use the PTO the fan is more likely to come on. At this time of year it should come on. Try heating the switch in a pan of hot water while slowly raising the water temperature.
Bob Rip
   / My 425 fan failed!! #82
When I mounted the switch I was certain it did have good contact and firmly attached...I will keep an eye on it and if it continues not to work I will connect the two wires together and run it off the ignition........
   / My 425 fan failed!! #83
" fluid for the wheel circuits does not go through the hydraulic cooler."
Thats interesting. I was doing some hard mini-hoe and loader work last week. The tank was getting pretty hot and wondered why the fan didn't come on. Maybe it would be better if the thermostat was attached to the tank.
   / My 425 fan failed!! #84
So the PTO lines run through the cooler?
(I haven't used the PTO much, that's probably why the fan hasn't came on yet)
I tested my fan today with a hair-dryer and it came on. First time it has since I bought the tractor last month. I was suprised how much air it moved. I did put a 30 amp fuse in just for kicks.
   / My 425 fan failed!! #85
The thirty amp fuse will now be protected by the wire burning up if there is a short circuit. I have a 10 amp fuse and I don't believe that it has blown. The fuse holder wore out at 400+ hours. Go back to a 10 amp fuse. Replacing the wiring is not easy. Having the tractor catch on fire (which is the main thing a fuse prevents) would be even worse. I am not an expert in this area, but I do have a degree in electrical engineering, I wired my own house, and I have designed production electrical equipment, and consumer electronics devices, so I am not novice either.
BobRip
amen... hallalujah brother. /forums/images/graemlins/wink.gif
   / My 425 fan failed!! #87
O.K, I'll put old fuse in. (BTW, it was a 20amp fuse)
   / My 425 fan failed!! #88
<font color="blue"> 30 amp fuse </font>
YIKES! /forums/images/graemlins/grin.gif
As mentioned, if you let the smoke out of the wiring, it is hard to get it back in. /forums/images/graemlins/wink.gif
Trust me, as I have done that and wished I hadn't... (and I have two degrees in electronics and did it anyway. Call it "hands-on experimentation". I just wanted to personally test all those theories they were teaching us /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/tongue.gif).
   / My 425 fan failed!! #89
O.k. All Set
I put the 20amp back in and tested the fan again. Works Great!
   / My 425 fan failed!! #90
So I believe I have learned from this discussion the cooler is used for PTO operations and if one is not using the PTO then the fan would probably not be activated. Interesting.
2018 Dodge 5500 Bucket Truck 4WD (A56438)
2018 Dodge 5500...
1979 Ford H-48 Excavator (A56438)
1979 Ford H-48...
John Deere 50 (A60462)
ALLISON TRANSMISSION (A55745)
ALLISON...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
