Comparison MX5400 Shuttle vs hst
/ MX5400 Shuttle vs hst #21
No wonder you have a difficult choice. I think that if longevity was the only issue then the nod must go to the shuttle. They are well proven to last the life of a tractor. For convenience and easy operation there is no doubt the HST is the choice. And HST longevity - probably not as long as a shuttle - may well be longer than you will own the tractor anyway.
Are those the only choices? There is a good intermediate choice on some models... the HST plus transmission. It has an electronically shifted two speed rear axle that it doubles the number of gears. A 3 speed HST becomes 6F & 6R. That eases the load on the HST pump and will probably help to reduce wear because the HST variable pump doesn't have to cover so wide a range. Less off-axis forces.
I like our HST+. It has been solid for 15 years now. But would say it also comes down to how you enjoy using a foot clutch. If you are comfortable with a foot clutch they work fine & there is certainly nothing wrong with the geared transmission choice.
My own favorite all time transmission was probably a 12 speed power shift with creeper gears, a foot clutch, and a reversing lever on the column.
rScotty
2 speed HST+ is great. But it's only available on the Grand Ls, not the MXes he's looking at.
If you keep up with the filter & fluids HSTs are in the same ballpark shuttles or power shift (GST) machines. Depending on usage & if you include splitting the tesctor fir a clutch they can rival a basic geared machine.
I do a lot of mowing along with light grading, loader work & other stuff. Geared efficiency would make sense for the mowing, but no way I'd give up HST ease of use for everything else. The 10% HP take for HST is well worth it for me.
/ MX5400 Shuttle vs hst #22
dbeverly68:
if some say the gear model has more longevity than HST (& i'm not convinced of that given the single dry plate clutch), then to OP:
how many hrs annually will you work it? how old are you? you're not using commercially are you? :)
/ MX5400 Shuttle vs hst #23
Dry single disc clutches for certain and in many cases forward / reverse synchronizers are by no means lifetime components.
A constant supply of clean, cool oil of the proper spec will allow an HST transmission to live thousands of hours.
Given proper care and use the choice is one of preference and suitability to the tasks at hand.
That's the key "Wet Clutch" vs "Dry Clutch", people are mistaken thinking that because is a manual transmission will last longer than HST.
First they have to check the type of clutch.
I know the Kubota M5660 has a Wet clutch, very robust components there.
/ MX5400 Shuttle vs hst #24
Right. Clutches are not equal. Wet clutches are remarkably long-lasting. They can go the life of the tractor.
Our Kubota M59 has a standard Dry clutch, but since it is coupled with a HST+ transmission it doesn't see much use. It just gets used to take load off the HST transmission when starting and for easing the PTO engagement.
Regarding clutch jobs....I'm changing the dry clutch in the John Deere 530 right now. It's a minor job because it was designed to be easy to do. A couple of hours of standing work at most, and no parts heavier than a few pounds. All clutches could be made that way. Wonder why they aren't?
rScotty
/ MX5400 Shuttle vs hst #26
I have an MX 5100 shuttle. I love the gear drive. Makes so much more sense to me. I use my tractor for fel dirt work, grading, grapple, box blading, a landscape rake, and mowing with a bush hog. Had a smaller Kubota with hst, hated it so much I got rid of it. I like to putz around in 1 gear, high range for most fel work. Set the hand throttle to about 1500 rpms and use the foot throttle for the power when I need it. I can't stand running an hst at almost 3,000 rpms for nothing. Go for the more power in the geared.
I run a M7060HD-12 the same way: I too agree.
/ MX5400 Shuttle vs hst #27
although all i've owned are gear tractors, i would favor those recommending HST. i once owned an MX5000 gear shuttle. i found the shuttle very primitive that requires clutch depression. plus (on that model) 1st & 2nd gears were not synched, only 3rd, 4th. if you are doing repeated fel work, you'd be forever shifting. plus, as mentioned above, the clutch is single plate/dry. it's going to wear out w/repeated use over the years. i'll let the HST people give more detailed info on that system
i found the MX to be a robust bare bones tractor & would not get the primitive gear model again.... i highly recommend the HST best of luck
The new ones are hydraulic shuttle, just like a regular Loader Backhoe, no clutching.
/ MX5400 Shuttle vs hst #28
i stand corrected. if the MX gear is hyd shuttle, no question, i would go w/gear. the hyd shuttle on my 12 sp M8540 is flawless.
glad to see they upgraded the MX series. given that, i change my recommendation to the hyd shuttle gear model for the OP
sorry for confusion, thanks for the info
/ MX5400 Shuttle vs hst #29
I am a first time buyer my self and have never operated a Tractor in my life before My Purchase.
I run my MX5800 HST around 1500 RPM while driving and between 1500--1800 operating the Backhoe.
It has all the power I need at those RPMs and the Backhoe is Jerky if I run higher RPMs (this may be me with lack of experience)
the MX5800 drives slower with the lower 1500 Rpms but it is not as loud.
When I need to pick the pace up I crank the RPMs up and go to the races.
I to have spun all four wheels while using the FEL.
Having the HST is GREAT for FEL work. But Again I have no experience to Compare to other Tractors.
I love my HST
Good Luck in your Choice
/ MX5400 Shuttle vs hst #30
I知 pulling the trigger tomorrow on an MX5400. I still haven稚 made up my mind on a shuttle or hst. The tractor will be doing mostly loader work with a bucket and grapple. I will also be mowing pasture. Mowing will be flat to tank damns and some hills. I guess I知 worried about longevity of either. Which may be better? I also worry about pushing brush and doing dirt work with the hst. I致e always had a shuttle and never owned a hst. Advise would be appreciated!! Thanks!
Disregard all the blather..here is the real skinny..........
From decades of experience in Kubota tractors, get an HST. In lieu of an HST, only a hydraulic shuttle. Neither have a dry clutch and for loader work, a dry clutch is the weak point and wear point and clutch replacement is always a split.
I would never own a dry clutch tractor with a loader on it. Loader work and dry clutches don't get along well. Well, they do in one respect, they get into your wallet for repairs.
The Kubota in my sig picture is a 2004. Bought new with a loader that I use constantly for moving and loading round bales, digging in manure piles and all sorts of stuff.
It has a hydraulic shuttle. So does my 2002, it's just like the pictured one but it's an open station. One has 2500 hours on it, the other has 5000 hours on it. neither have ever had a travelling clutch adjustment because both are hydraulic shuttle, IOW wet pack clutches. Only way to fly other than an HST.
/ MX5400 Shuttle vs hst #31
The truth is, how long a dry clutch last is more dependent on the operator than it is the type of clutch!!!
I've yet to have a dry clutch on one of my tractors fail on me, my neighbor has to put one in his tractor every 6 months or so... Watch him run the tractor and you can see why!
SR
/ MX5400 Shuttle vs hst #32
SR
This! Totally true! It does seem that a simple clutch pedal it's an extremely complicated thing to master for some people.
Over here, there are no HST tractors, unless it's special order.
Any good operator will put thousands of hours on a clutch, even with a loader on it. It's not uncommon to hear about the first clutch change at 4 or 5 thousand hours. Of course, 90% the cases, the tractor has only one operator. How many hydraulic oil and filter changes would a HST tractor have in 5k hours? It probably would pay for 3 or 4 clutches.
/ MX5400 Shuttle vs hst #33
I'd agree with that. Back when I had a mechanical repair shop, replacing customer clutches and throwout bearings were like brake jobs and tune-ups... a staple of the business. Clutch jobs are a simple straightforward replacement with minimal machine shop work, but with lots of simple mindless labor time. Businesses need that kind of work.
But my own machines have never seemed to need clutch work and I noticed the same for the mechanic's cars & trucks. So I conclude that the life of a standard dry clutch depends mostly on the operator.
OK, to answer your question, ptsg.... We change HST oil and filters annually or every 600 to 750 hrs. A trans/hydralic oil change costs roughly $400 to $500 materials per time and takes a couple of hours. Our labor is free, so in 5000 hrs we would expect 7 or 8 changes for $3000 to $4000 dollars - or about the same as a couple of clutch jobs. But we would still have to change the hydraulic oil even if we had a manual clutch. So those oil changes would still cost $2000 to $3000.
My favorite transmission has long been is a powershift with hydraulic reverser, and least favorite is the traditional foot-clutched non-syncro straight manual gear & range shift.
However, for our last new tractor (we usually buy used) is a HST+. It hasn't had a bit of problem doing some pretty hard work for 12 years now. And it is very handy to use in tight places. I'd say the HST is better for all the day-to-day "jump on the tractor" kind of chore jobs. The powershifting reverser better for Agriculture work. Both are durable.
rScotty
/ MX5400 Shuttle vs hst #34
rScotty
I agree with you in everything you said. Power shuttle is the best of both worlds indeed.
I have nothing against HST. In fact, it would probably be the right choice for my use. But seeing some people making such a big deal on a simple clutch just grinds my gears a little bit. Maybe they need to figure out how to properly use a clutch.
On the HST+, the main thing I care is the dual speed feature they offer. I bet that feature gets used a lot.
/ MX5400 Shuttle vs hst #35
With an automobile or a pickup truck, a clutch job is easy (unless it's a transverse engine). On a tractor, 99% of clutches require splitting the unit and with a bigger unit, that becomes a chore that most people leave to a shop and shop rates are running around 130 an hour. Between the labor and the parts, you can change a lot of fluid and filters and then there is downtime too.
With a wet pack and no clutch in the bellhousing, you get the best of both worlds. An infinity mopdulatable wet clutch, minimal wear (immersed in oil) and long life. Like I said, I have 5000 farm hours on my one tractor and the pack has never been adjusted (for lock up pressure) and it does serious loader work constantly. For me, the choice is very clear. For you. maybe not. You get fantastic life (clutch pack) and little parasitic power loss (gear drive transmission) and it don't take expensive fluid, ordinary hydraulic fluid with an EP additive for the gear transmission is all that is required.
/ MX5400 Shuttle vs hst #36
I've put semi load after semi load of this stuff, on my fields,
That's with a syncro shuttle (not power) and my leg didn't fall off, I could walk straight after every day and both of these tractors still have the original clutches in them!
AND I didn't have to listen to the diesel roaring away while I load or the whiner tranny, whining either!
SR
/ MX5400 Shuttle vs hst #37
SR
yep, clutches are very infrequently changed
/ MX5400 Shuttle vs hst #38
SR
Maybe that's because one of the tricks us old clutch guys learn is to pick a gear - or a range - and stay in it. No clutching required and speed is varied with the throttle.
One correction though, the modern HSTs don't have the diesel roaring away like the old ones did. Today's HSTs can have automatic throttle load response & automatic return to idle.
On our HST+ tranny, when I advance the HST control to get going, the engine only revs as much as it needs to match the load. And the moment I back off on the HST rocker the engine immediately returns to idle.
So the old HST "max RPM diesel roar all the time" problem is no longer necessary. You can buy a HST that doesn't do that. Although I notice that on ours there is also an over-ride control lever so I can set it to be constantly roaring away at full throttle if I'd rather. (I'd rather not)
rScotty
/ MX5400 Shuttle vs hst #39
SR
Betcha got a lot of weeds........................:laughing:
/ MX5400 Shuttle vs hst #40
Before i got my hst i thought my shuttle was the only way to go.Now i love my hst . I also have bad knees so not having to clutch is great. i can also go back and forth with loader or brush cutter while looking backward without having to stop turn around shift then turn back. saves a ton of time.
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
2002 CATERPILLAR 247 SKID STEER (A64279)
2002 CATERPILLAR...
ROLLS OF CHAIN LINK FENCE (A64281)
ROLLS OF CHAIN...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
