MX5400 Air-conditioning? ? ?
/ MX5400 Air-conditioning? ? ? #21
My cab unit has 4 filters up high on the cab. I blow out the filters once a year to keep them clean. The radiator has a manufacturers installed removable screen that traps nearly all chaff. Easy to remove and clean.
air is always freezing cold. No need for window tint on my unit. Was out working in 93f yesterday, and unit was blowing cold air within 30 seconds of startup. I think my tractor blows colder air than my trucks do.
/ MX5400 Air-conditioning? ? ? #22
With the window tint don't need sun visor and the
sun don't blind you
willy
/ MX5400 Air-conditioning? ? ? #23
Do you remember if it cooled from the start and has degraded or has it always been this way? Since this is your first summer its difficult to know a baseline. If it cooled early in the year but is hot now, then something like plugged condenser might be the problem. If it has always been this way, likely a system problem. Example - my BIL got a new (used, but new to him) tractor this spring. His son's operation has a lot of running tractors, either open platform or cab with inop A/C. He got this one because of his age (just turned 74) and can't handle the heat anymore. Midway through cutting first crop hay, he asked me if sweating in an AC cab is normal because it didnt' seem any better than open platforms or cab with all windows but the windshield missing. I checked and his compressor wasn't running. Defective pressure switch. Replaced it and now he's very happy. Something like this likely your problem, and considering its new, warranty.
I now have 3 Kubotas with A/C and had 2 others traded off for the ones I now have. Even though I live in Northern Minnesota where one wouldn't think A/C is all that important, we do have our days in the 90s. Having spent half my engineering career with AGCO and CNH, I can say that Kubota's A/C system is not the most powerful. Ag equipment cabs have so much glass area they need a lot more cooling than cars and pickups. Systems we had on Gleaner and Case IH combines were much larger than anything in a car - according to our A/C suppliers. On a 40 degree late autumn day in a combine, an operator still needs a lot of air conditioning when the sun is out while in a car you likely need heat.
/ MX5400 Air-conditioning? ? ? #24
Agree, but I'd bet money they're sized as big as they can be while meeting other anticipated power draws without upgrading power generation on the machines.
/ MX5400 Air-conditioning? ? ? #25
I am heading out to work in my M7. After fueling, I ran for about a minute and checked temperature at the outlet nearest the A/C evaporator - 40 degrees or less with 80 degree ambient. Sky is clear of clouds but obstructed by smoke from our nearby forest fires so its not getting a full sun load.
/ MX5400 Air-conditioning? ? ? #26
am i misreading this. or has he found the issue with the cable
/ MX5400 Air-conditioning? ? ? #27
Actually, the way I read it is that he is at this moment on his way home to try to sort it out....
"I'm in town on business until Friday, noon... As soon as I get back I'll check all the suggestions... I can't wait to get home to check these things out.
/ MX5400 Air-conditioning? ? ? #28
i think your right...i think i am referring to a different thread i read. i remember yesterday someone saying he found the cable wasnt opening the diverter valve, but the entire cable was just moving. they opened the door manually and air flowed. not sure where i read that though.
/ MX5400 Air-conditioning? ? ? #29
Won't that be funny if it turns out to be the problem here as well then? 😁
/ MX5400 Air-conditioning? ? ? #30
about 1/2 way down. funny, i read thry it yeaterday and thought it was referring to this post. heat on my brain i guess. its 98 F here today...yuk
Toro (A56857)
Toro (A56857)
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
John Deere 5100M (A53317)
John Deere 5100M...
2014 Ford Escape SUV (A59231)
2014 Ford Escape...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
