Mx5100 spitting the dipstick out?!?
/ Mx5100 spitting the dipstick out?!? #21
I believe there is a crankcase breather valve on the valve cover. There is a hose from this valve to the intake manifold. I am assuming your engine is fairly similar to my L5740. The workshop manual doesn't illustrate the valve very well - there is a top view showing 4 attaching screws holding a cover that might access the valve. On my tractor I can barely see the hose because of 2 tanks covering it. Back in the 60's when they first started putting PVC valves on cars my dad bought a car where the corresponding valve tended to freeze in cold weather and blew out the valve cover gasket a couple times before they came out with a fix. This sounds like what is happening to yours. And yes, PVC is new to many off highway diesels. Tier 3 engines I worked with still had an open breather tube - just an open hose that directed the fumes down and out. Your 2012 tractor under 75 HP is Tier 4 interim and I believe PVC became required. The only older diesel I still have is a 2005 mini-excavator with a straight out hose and the crankcase fumes from that little engine are quite impressive, and smelly. It sounds like Kubota has a problem with their valve that cropped up due to this odd winter.
Just to the right of the beer bottle, 4 screws, remove carefully because there is a diaphragm and small spring underneath. Most likely it froze there. Good luck! Fred
/ Mx5100 spitting the dipstick out?!? #22
I don't think it's a pollution thing at all. I think the breather tube is to get the cranckcase vapors away from the intake so the filters stay clean.
Also, if too much vapor were fed back into the intake, under the right conditions the engine could run away.
It is in fact STRICTLY for emissions. The recirculate back to the intake.
On a lot of the old 2 stroke detroits the vent was run to the air intake. I don't think I've ever seen that on a 4 stroke diesel. A lot of them run a hose or pipe from the actual breather cap to some sort of remotely mounted canister or filter where oil mist is trapped but the gasses can still vent.
Maybe the newer silver series, all the old ones just had a dump tube. As a matter of fact the only ones I have that recirc like a normal emissions engine is the newer 6v53t military power packs.
/ Mx5100 spitting the dipstick out?!? #23
"I don't always drink Dos Equis, but when I do, I put turbos on little tractors....stay thirsty my friends...."
/ Mx5100 spitting the dipstick out?!? #24
(that was meant for Fred's picture)
/ Mx5100 spitting the dipstick out?!? #25
Yup it is all about emissions Wayne. Be ready for all the emissions related BS of the 60 series tractors coming to a farm near you soon!
I have a photo of the actual diaphragm somewhere been looking for it. It's made of the same orange silicone crap that all the car OEMs use. After time they split/tear and cause a check engine light. Not on Kubotas YET LOL!
Fred
/ Mx5100 spitting the dipstick out?!? #26
Run a loop of1/4" or 3/8" hose with hot engine coolant around the valve/hose that freezes. Alot of cars and trucks have coolant through the pcv valves now.
/ Mx5100 spitting the dipstick out?!? #27
Replace the thermostat........or put a piece of cardboard in front of the rad.
/ Mx5100 spitting the dipstick out?!? #28
Primary products of diesel combustion are carbon dioxide and water. The water vapor that gets past the rings into the crankcase has to go someplace and that path is out of the breather. It hits your cold PCV valve and freezes blocking the passage. Blowby must go somewhere and the dipstick is the path of least resistance. There may be no problem running without the dipstick until things warm up but that narrow tube may be too small to handle the blowby and like someone mentioned, the next weakest point may be a crankshaft seal. Something like this happening on a modern engine after 50 years of history with positive crankcase ventilation is due to PPD - P*** Poor Design if like you say your dealer is reporting a shop being loaded up with machines having the problem. You have me worried because I have 3 Tier 4 interim Kubotas; however, the one that now has about 250 winter hours over the past 2 years has not had a problem so maybe the heated garage is the answer.
/ Mx5100 spitting the dipstick out?!? #29
That's a really great idea. Maybe insulate over the top of the valve cover just for cold weather. That pink Owens-Corning stuff will take the heat of exhaust headers with no problem, the mice love it too.
Fred
/ Mx5100 spitting the dipstick out?!? #30
Thanks. Maybe use copper for the heated area and rubber to get it there?
/ Mx5100 spitting the dipstick out?!? #31
If temp gauge isn't getting past the indicator dot near the bottom (at a minimum) then probably running at higher RPM would help.
/ Mx5100 spitting the dipstick out?!? #32
my wife's car has a service bulletin on it for the hose on the PCV freezing. The problem is the molded & shaped rubber hose collects condensation in a dip, which freezes, blocking the hose. The fix is to replace the molded hose with a regular bulk type rubber hose, and routed over the top of the engine so it has no dips.
So:
is it rubber? (can you squeeze it to find the frozen part)
are there any dips in what you think is freezing?
can you reroute to avoid dips?
And of course it was the coldest it has been here in the last couple years. I had the tractor out today and it was about 15 degrees out. No issues and it ran wonderfully. I guess the heated garage just moved up the wish list!
/ Mx5100 spitting the dipstick out?!? #34
So:
That's great advice. I haven't had a problem with the PVC on our M59 freezing....but as someone noted, PVC's are a new device in the tractor world and we haven't yet seen the whole range of winter weathers either. So more failures are likely.
Thanks to The Fred's for the picture posted in message #21. It shows the standard PVC hookup on his tractor and I can see that it doesn't have a dip in the hose....but what they've designed there looks to be a near perfect water vapor condenser with the PVC valve itself being the lowest point in the system. That's not so good.....
However, knowing about a problem and actually taking the time to fix it are surely two different things. This problem is simple and well-known to an earlier generation of mechanics. So the fix is easy enough. But knowing all that, I still haven't done anything about it on my own tractor. Has anyone? The most basic fix would be to remove the diaphram and spring from the PVC, reassemble PVC as a shell, run a hose DOWN from the PVC to a fabricated cannister*, and not forget to block off the port on the intake manifod. Agree?
luck, rScotty
* hmm.....rather than fabricate a canister....I remember that a variety of breather cannisters were standard on most older cars. Or maybe there is a universal one at the auto store? Or on Ebay?
