Mx5100 let me down!
   / Mx5100 let me down! #41
CJBOTA- any chance you remember the name of the wood boiler? Was it your typical OWB? Or a long sub like unit?
Flyingcow,
Don't know the brand name. But it was huge. Shaped like a small storage shed. He said it was a steal at $3000. I was just able to get the bucket high enough to clear the roof with about 6" to spare.
CJ
   / Mx5100 let me down! #43
Some of those units are crazy heavy. My units an indoor boiler, about half the size of a frig. just under 1200lbs.
The soft ground and high pick was a bad combo. It's bad feeling when you think you're going over.
   / Mx5100 let me down! #44
Probabally not as much as the mud you had packed around your front axle in your avitar:laughing: Got a story behind that pic:licking:
Seriously though, according to what I could find online, asphalt is ~145lb/cu ft. And my L3400 heaped I think is like 9 cu/ft (1/3 yd) so your 1ft wider bucket should be closer to 11 or 12 cu-ft heaped.So thats somewhere between 1600 and 1800lbs. Just guessing though. Which probabally isnt bad since the capacity of your loader is like ~1550lbs @ bucket center. Asphalt is a good bit heavier than sand, stone, or dirt by volume as you can see. Same volume of sand would have been ~500lbs less.
Also keep in mind that the loaders on the economy L-series arent nearly as strong as kubotas grand and M models. They arent as strong as some of the competition, but except for rare ocassions, they dont need much more.
Well, one day I decided I was gonna try and cross the creek with my tractor and knew the shore/edge line was soft in certain places. So I tried another area and instead of getting off the tractor and checking the area first, I just went for it. Well the mud was well camouflaged by leaves and down I went. Luckily the rears were still on solid ground so with diff. Locked and help from the loader I got out. I'm gonna build a bridge to get the creek in the near future.
If your calculations are correct or close to the weight of asphalt millings, then I really can't complain about the loaders performance that day. Thanks for that info:thumbsup:
   / Mx5100 let me down! #45
Not really sere about the "millings", I just googled "how much does asphalt weigh per cubic foot" and 145lbs seemed common.
Let us know and take pleanty of pics if/when you decide to do that bridge:thumbsup:
   / Mx5100 let me down! #46
I loaded my L5740 tires with RimGuard and it made a HUGE difference. 1298 lbs of difference to be exact. This is my 3rd Kubota that I have loaded the rears with the stuff and I'll never own another without doing it first thing.
Yea, now that I have had to think about it I feel bad about the title of my thread. I guess I shouldn't have said it let me down when I tried to do something stupid. However, the MX5100 does need alot of ballest when using the bucket. I'm sure that new back hoe will work just fine.
CJ
   / Mx5100 let me down! #48
CJ
Don't feel bad, my L4400 is the same way. Quite scary with no ballast. My rears are filled but its no where near enough.
   / Mx5100 let me down! #49
It's not too difficult to get my back wheels off the ground even with loaded tires & a 600 lb grading scraper hanging off the back. So I'd say that if you want to be able to really utilize your loader, loaded tires are a must. And something very heavy on your 3 point hitch is probably a must, too.
In fact, just yesterday I was lifting underbrush out of an area full of saplings. As I was backing up, a bent over sapling caught the end of the far-right tooth of my grapple bucket, & even that caused the back wheels to come off the ground. I was a little :shocked:
   / Mx5100 let me down! #50
My box blade is close to 700 pounds and is not enough, so when possible, I use my 1000+ cutter. I have some sections of RR track to put on my bb when my son can get around to cutting them to length.
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
Case IH 1063 Corn Head (A50514)
Case IH 1063 Corn...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
UNUSED AGT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SKID...
RURAL KING RK37 TRACTOR (A51243)
RURAL KING RK37...
