Mx5100 let me down!
   / Mx5100 let me down! #51
Yep, ballast is a must. I use a 700lb blade behind me + loaded tires. And my L3400 is ALOT smaller than you guys' tractors:thumbsup:
   / Mx5100 let me down! #52
My box blade is close to 700 pounds and is not enough, so when possible, I use my 1000+ cutter. I have some sections of RR track to put on my bb when my son can get around to cutting them to length.
More importantly ... where did you get RR track??! I could come up with some uses for some of those :thumbsup:
   / Mx5100 let me down! #53
A RR company discontinued service on tracks that went through our property about eighteen years ago and merged with another company. They came through and picked up all of the track and ties as well as the heavy rock on the top, but let us have the gravel that formed the bed.
We let our renters have the gravel for cleaning it up and we also picked some up with our tractor and dump truck to use on our roads. Our renters also hauled some for us. While digging the bed up, we found two fourteen foot sections of RR buried. At the time, we had no use for them, so my father in law and I took them back off one of our roads and put them off to the side so no one would get them as we knew someone would and knew some day we would find something to do with them.
Well, as so often happens, over time, we forgot all about them and my father in law died. Last year while working along one of our roads, I saw something in the brush and decided to see what it was. It wasn't until, I uncovered them that I remembered putting them there.
We are guarding them like gold as no one seems to know where you can get them. They use to be fairly common as my dad used sections as anvils.
Now I just have to be sure all my kids know where the other one is as I only took one out.
   / Mx5100 let me down! #54
Back when I had my 5030 it got light on the backend ocassionally so I went to TSC and bought one of those right angle pallet lifters, welded on a sheet metal box and filled it with concrete. I had to weld on a pair of angle supports to. I bet it weighs nearly 1000 pounds. Don't use it anymore and now it's a toe stubber....lol
Someone wants it and they are nearby, they can come and get it for free..... It's for a Cat 1-2 3 point and I'll load it on a pickup or trailer. How you get it off is your problem.....
   / Mx5100 let me down! #55
I have 750 lbs on the back of My L3400HST and loaded tires, and last weekend I was nose down a steep grade (only kind of grade we have here in branson:)) I was trying to pick up a big piece of concrete out on the ends of the forks, and the wife said the tires came up off of the ground.. I did not notice..:eek::eek: The times before when I have hooked on to a big rock on flatter ground, the relieve kicked in before the tires lifted, but maybe downhill.. not so much!
James K0UA
   / Mx5100 let me down! #56
Up high all lifting equipment is dangerous. Think of a triangle and understand that as the triangle gets longer it gets much more unstable at the base. Levers and all that. When ever I question a load I lift very slowly. Very very slowly. That way if the wheels lift off I am ready for it and can just drop the load. Yes it happens fast. I hate that feeling. I was pushing some rock around just last week and a back wheel lifted off.
Did you have the seat belt on? Remember if it goes don't try and jump, just hold on.
   / Mx5100 let me down! #57
Back when I had my 5030 it got light on the backend occasionally so I went to TSC and bought one of those right angle pallet lifters, welded on a sheet metal box and filled it with concrete. I had to weld on a pair of angle supports to. I bet it weighs nearly 1000 pounds. Don't use it anymore and now it's a toe stubber....lol
Sounds like a good idea. I have considered fixing something up like that or a concrete filled barrel as my bb sometimes gets in the way in tight woods.
James K0UA
James, our hills are nothing compared to yours, but even with the 1000 pound cutter, I have picked the rear end off the ground a bit backing out of a ditch or gulley with a full bucket. Like you, I really don't notice it, but I pretty much know when it is going to happen and it comes down pretty quick. I keep the bucket really low.
I saw the guy who owns the furnace I tried to lift. He said it turns the furnace almost weighs 2000 lbs. If I had know that I wouldn't have even tried to lift it at that height. Another lesson learned, question what people tell you, especially when it looked heavier. That thing was about 4' wide x 7' lg. x 6' high at the peak of the roof.
CJ
   / Mx5100 let me down! #59
CJ
To make that 2000 pounds and lift it that high without typing over without enough ballast in the rear makes that a really good lift IMHO!
   / Mx5100 let me down! #60
CJ
I figured it was a biggie.
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
YALE STRAIGHT MAST FORKLIFT (A51242)
YALE STRAIGHT MAST...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
