MX5100 injection pump failure
/ MX5100 injection pump failure #1
DSM123
North Texas
MF203, MF135, IH2400A backhoe
Bought new 5 years ago, 215 hours logged. Filters and maintenance performed as required.
Now it has a failure with the fuel injection pump. Dealer wants $2400 to repair it.
Is there a place that can rebuild the IP? I can remove and reinstall it.
I’ve worked on diesels for 40 years and have never seen a pump fail in such little time.
/ MX5100 injection pump failure #3
What's your tractor's IP failure symptoms? Southwest Metro fuel Richland Hills, Tx (817) 595-0855 or (817) 589-1703
/ MX5100 injection pump failure #6
I’d b happy to help you out..
Just contact me directly or send me a prvt msg thru here.
/ MX5100 injection pump failure #7
I would really appreciate knowing what happened to that pump!!?? I always thought the V2403 engines were pretty indestructible including their injection pumps.
Please keep us posted!!
/ MX5100 injection pump failure #10
I’m still around and helping people with their inj pump problems.. I’d be happy to give u a hand..
I can contact thru here are at my email.. my screen name at aol dot com
/ MX5100 injection pump failure #11
in keeping with the OP's post, as an injection pump specialist, what are the most common problems re: pump failures, basically mechanical wear failures, or fuel contamination, water in system, etc.
had a pump shaft failure on a TO35 back when, but attributed it to a typical age related mech failure. regards
/ MX5100 injection pump failure #12
By far, fuel contamination & lack of basic maintenance..
No fuel filter changes, which lead to pumping plunger wear AND air filter changes which leads to cylinder wear and low compression..
ie: dusting the engine
I guess we can throw in regular engine oil and filter changes too..
But being strictly a “pump guy”.. it would have to be fuel contamination..old fuel, dirty fuel and Bio-fuel would be my top 3..
Then theres the problem of the hardened control sleeves, where the teeth break off..
& to be completely honest, I have never ran into this problem UNTIL I came to this site..(no kidding)
/ MX5100 injection pump failure #13
good point, all the more reason for scheduled fuel filter changes, reliable fuel suppliers, & proper storage tank maintenance. plus fuel treatment for the application. going back to the OP, still curious as to why the pump failed w/such low hrs.
/ MX5100 injection pump failure #14
I'm interested in the outcome as well, maybe the OP is too busy to update the thread
/ MX5100 injection pump failure #15
Thanks for the info thepumpguysc!! Was wondering if you are aware of any known issues with the mechanical injection pumps on the Kubota V2403 engines?
Sorry for the delay. Here’s what happened.
At roughly 215 hours the v2403 developed a dead miss on cylinder 3. I determined this by loosening the injector lines.
It was noted that there was no fuel coming out of the number 3 delivery valve on the IP.
I removed and pop tested all injectors and although they looked ok I would not say they looked great for having only 215 hours on them. Spray pattern was not perfect. I’ll obtain new nozzles and address that later.
Meanwhile, I removed the IP, which is a Denso pump, tore it down to try to determine what failed.
I saw no scoring or broken parts. Everything looked very good so I put it back together and reinstalled it. Now it runs just fine.
I am puzzled as to what happened.
It did run out of fuel prior to this event but ran ok after refueling for a few minutes.
I’m thinking I got some contamination in the refuel and maybe caused one delivery valve to stick. Who knows…
Now, to try and sort out why the loader hydraulics bypasses when warm. She really looses power and barely lifts a bucket full of dirt when it’s warm. There must be a way to adjust the pressure.
/ MX5100 injection pump failure #17
Thanks for updating the thread. So you took it all apart, shrugged and put it all back together and it worked. I hate when that happens but atleast it wasn't an expensive fix and just cost you some of your time.
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
