MX5100 at work
/ MX5100 at work #41
I'm clearing some of the dead ash near my septic right now. Skidded 10 logs up the other day. Quite a few more yet to cut.
/ MX5100 at work #42
THese are some great pictures guys! Thanks for posting. I really like that FX90 on the back of the tractor!
/ MX5100 at work
Here's a couple pics of a little bushogging job I did the other weekend.
/ MX5100 at work #44
Looks good!
Here's some of the ash I've been yanking out.
/ MX5100 at work
Started a barn pad the other day. Used the MX to sort all the logs and brush.
/ MX5100 at work #47
Great pictures. The MX looks in its element in the picture with the loader up.
/ MX5100 at work #48
cool thread.. some nice action pics of the mx5100
/ MX5100 at work
Thank you both. I just thought I'd start a thread to show some if the work I've completed with this tractor. When I was tractor hunting I couldn't find many action shots of an mx5100 so I thought I'd fix that.
/ MX5100 at work #50
its nice to see some pics of your tractor at work. nice machine you have there... cheers
/ MX5100 at work
Put some good hours on the tractor as I had some lumber milled for my barn project. There were three of us and we did Jst shy of 6000 bf in about 12 hrs.
/ MX5100 at work #52
Very nice.
/ MX5100 at work #53
Very impressive lumber project.
/ MX5100 at work
Yeah and the sad part is I only have about half what I need. I need to round up quite a few more poplar logs this winter.
/ MX5100 at work #55
How much weight do you have in your wheel weights? Are your tires filled also?
HP
/ MX5100 at work
I believe the weights are around 100lbs a piece and I'm running two on each side. Tires are loaded with rim guard and it's still not enough. I have a sheet of 3/8" plate I'm gonna make a skid plate out of. That oughta add some weight...
/ MX5100 at work #57
I agree, not enough. I keep my 550 lb box blade on the back all the time for loader work. The rear tires are filled with water and wiper fluid. I could use another 500 lbs. I've been looking for some old cut up railroad rails to add to the top of the box blade. My 1,100 lb 3 pt backhoe definitely makes a difference when it's on the back, it just sticks out too far when it's on.
/ MX5100 at work #58
Over the years I've done a lot with misc iron on implements but on tractors the best I have ever found is factory wheel weights. They might cost a little more but they work better than other options I have tried. Just my two cents here.
/ MX5100 at work #59
Some suitcase weights work on some box blades
/ MX5100 at work
The lack of rear end weight is my biggest (only?) gripe about this tractor. I wish kubota would design another 600lbs in the rear end. With that said...I need a skid plate badly anyway so I'll get her fixed up. I may also build a weight box I can hang on the back of my skidding winch to add some extra heft when loading logs. At almost 800lbs the winch still isn't enough at times.
1994 Geo Tracker, 5spd, Soft Top (A62679)
1994 Geo Tracker...
Coleman Minibike (A65579)
Coleman Minibike...
2023 Ranger 1000 XP North Star (A62679)
2023 Ranger 1000...
LEEBOY SUPER 400 DOUBLE DRUM ROLLER (A65053)
LEEBOY SUPER 400...
New/Unused Landhonor No Till Seed Drill (A65583)
New/Unused...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
