MX5100 at work
/ MX5100 at work #41
I'm clearing some of the dead ash near my septic right now. Skidded 10 logs up the other day. Quite a few more yet to cut.
/ MX5100 at work #42
THese are some great pictures guys! Thanks for posting. I really like that FX90 on the back of the tractor!
/ MX5100 at work
Here's a couple pics of a little bushogging job I did the other weekend.
/ MX5100 at work #44
Looks good!
Here's some of the ash I've been yanking out.
/ MX5100 at work
Started a barn pad the other day. Used the MX to sort all the logs and brush.
/ MX5100 at work #47
Great pictures. The MX looks in its element in the picture with the loader up.
/ MX5100 at work #48
cool thread.. some nice action pics of the mx5100
/ MX5100 at work
Thank you both. I just thought I'd start a thread to show some if the work I've completed with this tractor. When I was tractor hunting I couldn't find many action shots of an mx5100 so I thought I'd fix that.
/ MX5100 at work #50
its nice to see some pics of your tractor at work. nice machine you have there... cheers
/ MX5100 at work
Put some good hours on the tractor as I had some lumber milled for my barn project. There were three of us and we did Jst shy of 6000 bf in about 12 hrs.
/ MX5100 at work #52
Very nice.
/ MX5100 at work #53
Very impressive lumber project.
/ MX5100 at work
Yeah and the sad part is I only have about half what I need. I need to round up quite a few more poplar logs this winter.
/ MX5100 at work #55
How much weight do you have in your wheel weights? Are your tires filled also?
HP
/ MX5100 at work
I believe the weights are around 100lbs a piece and I'm running two on each side. Tires are loaded with rim guard and it's still not enough. I have a sheet of 3/8" plate I'm gonna make a skid plate out of. That oughta add some weight...
/ MX5100 at work #57
I agree, not enough. I keep my 550 lb box blade on the back all the time for loader work. The rear tires are filled with water and wiper fluid. I could use another 500 lbs. I've been looking for some old cut up railroad rails to add to the top of the box blade. My 1,100 lb 3 pt backhoe definitely makes a difference when it's on the back, it just sticks out too far when it's on.
/ MX5100 at work #58
Over the years I've done a lot with misc iron on implements but on tractors the best I have ever found is factory wheel weights. They might cost a little more but they work better than other options I have tried. Just my two cents here.
/ MX5100 at work #59
Some suitcase weights work on some box blades
/ MX5100 at work
The lack of rear end weight is my biggest (only?) gripe about this tractor. I wish kubota would design another 600lbs in the rear end. With that said...I need a skid plate badly anyway so I'll get her fixed up. I may also build a weight box I can hang on the back of my skidding winch to add some extra heft when loading logs. At almost 800lbs the winch still isn't enough at times.
