Mx5000dt question
/ Mx5000dt question #2
I suppose if you needed weight a bucket full of dirt or gravel might help
/ Mx5000dt question #3
Adding front weight is probably not necessary, but that is the operator's decision. There have been problems with Kubota's front drive shaft couplers associated with not adding rear weight, when using the FEL with 4wd engaged. Apparently, without extra rear weight the front wheel drive is stressed and there have been coupler failures and shaft spline damage resulting.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2013 FORD TRANSIT CONNECT VAN (A66091)
2013 FORD TRANSIT...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
1 PALLET OF JACK & IMPACT GUNS (A66091)
1 PALLET OF JACK &...
UNKONW  TRIAXLE ALUMINUM VACUUM TRAILER (A67714)
UNKONW TRIAXLE...
2022 LEVEL BEST GB100 108" HYD GRADER BLADE (A65053)
2022 LEVEL BEST...
