MX5 bushhog question
/ MX5 bushhog question #1
jmt1271
Platinum Member
MO
Kubota L2501
I know where I can get a "new" MX5 for about $1300. It is about 2 yrs old but has never been sold. Of course it has the full warranty, but it is weathered some. They have touched up the paint etc... It doesnt have guards but I am thinking I might get them to throw some in as they really want to move it. Is this a great deal or just okay? I really dont want to spend this much, but might if it is a smoking deal. Know what I mean?
/ MX5 bushhog question #2
On the JD site they go for $2059.00 list--but that includes front and rear safety chains/shields.
/ MX5 bushhog question #3
There was a MX6 on ebay just last week that was just like new (think the guy said less than 20 hrs use). Anyway, it went for $1525.
Seems like $1,300 for a NIB MX5 ain't too bad a deal --- would be real hard to pass up if they throw in the chain guards.
I'd probably be reaching for my checkbook...
AKfish
/ MX5 bushhog question #4
I paid 1300 for one with about 25 hours on it, 2 years ago. Yeah, that is a smoking deal.
Well I just talked to the salesman. The deal is this $1395 for the MX5 with no guards. Best he is willing to do. I asked him to email me a few pics as it is about an hour away. I will check it out and if it looks good, I may try and get it.
Before I do though, do any of you veterans think I could go with another brand and find a better buy for $1395?
/ MX5 bushhog question #6
Not for the same quality. MX5 is high quality, similar to Woods. I think other brands for that price would be more average quality.
I will say that I think you need to have guards on it, whether you buy from him, buy from someone else, or make some.
Does anyone have experience with an MX5 behind a 3520? It is listed as the biggest RC the tractor can handle. Will a 3520 handle the MX5 well?
/ MX5 bushhog question #8
I bought the MX-5 with my 3520 and it has no trouble at all with it as long as you run it at mowing speed. I am very pleased with it but it might be a little heavy if you don't have a FEL or some front weights.
I do have a 300CX so I guess I should be okay. What do you mean "mowing speed"? Are you talking ground speed or PTO speed?
/ MX5 bushhog question #10
I have a 3320 that I use with a MX6. I keep the loader on for front weight and it pulls it fine. I actually bought the MX6 for a 65 hp tractor but tried it on the 3320. I'm using it on the 3320 now because it is so much more manuverable, has better visability and e-hyro. Shifting gears on the big tractor is a pain.
If I'm going to mow ditches or get on any slopes I will use the big tractor just to make sure it doesn't get away from me. The 3 point hitch picks it up fine with the I-match and the pto power is sufficient. I may have problems in weeds 3 or 4 feet tall but it does fine in grass that is only a foot or two.
/ MX5 bushhog question #12
I also have an MX-5 on a 3320 with 300CX loader to balance things out, and have no problems at all. It does 'lug down' a bit when I first turn on the PTO, but I've learned to cycle it on/off/on during startup, and it works very cleanly now. Cuts the grass/brush very well, maneuvers well, and does not seem to be "too much" for the tractor.
I *did* have to learn the hard way that you can't mow at a 90 degree angle down the terracing... I bent the metal braces when the tractor hit the level ground, the pivot on the 3PH maxed-out it's travel, and the MX-5 was still trying to keep the tractor's back wheels off the ground. Let's see... 2 four foot long, 1/4 inch wide pieces of steel (even painted green) versus a 2,900 lb tractor and 900 lb FEL -- no contest. :eek: But of course this has nothing to do with the tractor/cutter combo -- more with the tractor/idiot-operating-it combo!
Anyone know the best way to straighten out those braces? :rolleyes:I'm assuming I could just lay them flat on the ground and "tap gently" with a rubber mallet until I work the kinks out...
/ MX5 bushhog question #13
I'll betcha those braces are at least 3/8" thick. If you've got a torch, you might be better served to heat them before you try to straighten them out.
Even a small propane torch (used to solder copper pipe, etc.) would help to coax those braces back into shape.
If you don't want to chip up your garage floor, a flat steel plate is a good surface to pound on or I've even used some scab 2x6's, etc. Sometimes I've broken up 2-3 pieces of wood before I'm done but it's better than making a mess of the concrete floor.
A small 2-3 lb sledge hammer will get you there faster than a rubber mallet and help with the small "tweaking" increments that you just "need" to finish!
And you'll get to drop into your local JD dealer and buy a spray can of JD "green"!
AKfish
/ MX5 bushhog question #14
Another 3320/MX5 combo here, no problem at all with blackberries, hawthorne, you name it. I always drop the RPMs to ~1500 before engaging the rear PTO, then ramp up to full PTO RPMs. If I engage at full PTO RPMs, it's not as smooth starting up.
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
iDrive TDS-2010H...
2021 Sol Grand Design BK390 Camper (A62613)
2021 Sol Grand...
17601CFL (A59228)
17601CFL (A59228)
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
