MHarryE
Elite Member
- Joined
- Feb 15, 2009
- Messages
- 2,983
- Location
- Northeastern Minnesota
- Tractor
- Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
I know most everybody on the forum owns CUTs or SCUTs, but I think there are a few around with larger Kubotas. My M135GX is due to be delivered today or tomorrow. I picked up the manual and went over the controls with the dealer yesterday. First, I assume the power shift transmission is similar to the M135X except for an extra range. In shifting between ranges, it states in the manual that you must both depress the clutch pedal and press the clutch button on the shift handle to shift ranges. Is this true? Our New Holland TS115A has something similar, a clutch pedal and also a clutch button. You can use the clutch button alone to shift between ranges. It appears that except for starting, the button performs the same function as the pedal. Our John Deere 7720 and 6630, however, have no button. They require using the clutch pedal to shift between ranges. Not a big question but there will be other people driving the Kubota and a couple are used to driving the New Holland and Deere. This tractor is different in that according to the book you need to depress both. You can't see the button - it is on the side away from the operator so you need to find it by feel. If a person switches from the Deere to the Kubota, they may not know/remember the button. If a person switches from the NH to the Kubota, they may want to shift using only the button. So curious as to experienced users. Anxious for the tractor to arrive although we have done most of our spring planting with the other tractors and just had 4 days of rain so once it is here it will be the wait for ground to dry.
