MX 5000 ???
/ MX 5000 ??? #1
indytractorBob
Southern, IN
Branson 3820i
I stopped buy the local Kubota dealer today and got a price quote on a 4wd MX 5000 w/o FEL. Is this tractor big enough to cut, and bale approx 30+ acres of alfalfa? I am also considering a Case IH JX 55, JD 5203, and a 1996 Ford 4630 W/ fel. Any recommendations? Please let me know. Thanks.
Bob
/ MX 5000 ??? #2
I'd say the MX5000 would be adequate but marginal. If you're making small square bales, dropping them on the ground (as opposed to pulling a wagon behind the baler), baling on fairly level ground, and taking your time; you should be fine. I know I've baled with far less tractor than the MX5000 (Ford 2000) under similar conditions. You would probably be OK pulling the wagon if your land is table level; but I don't think you should expect to run a bale thrower. The others you're looking at would be better only from the standpoint of increased tractor weight; the same restrictions would apply.
There are others here much more into haying than I. You'll probably get better information from them. Like you, my hay acreage is rather small.
FWIW
Bob
P.S. What were you quoted on the MX5000, if you don't mind my asking?
/ MX 5000 ??? #3
We pull a JD 14T baler with our Allis Chalmers D15. It is a 4200 pound tractor rated 42 hp. I think the MX 5000 would do the job, but would be a bit small. I would feel comfortable, but then again I am a bit crazy. I have pulled the baler on flat ground with my L3400. Does a great job in my opinion, but again I seem to push things to the limit. I am sure it would cut it very well.
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
429872 (A61166)
429872 (A61166)
2022 TrailMaster Gas Cart (A61574)
2022 TrailMaster...
Coleman Powermate Generator (A62613)
Coleman Powermate...
