Murray 3.5hp add throttle
/ Murray 3.5hp add throttle #1
Fuddy1952
Elite Member
South Central Virginia
1973 Economy and 2018 John Deere 3038E
I have a Murray 3.5hp (don't laugh...$99 special ) push mower I had stored/years. I changed oil, sharpened blade, etc., runs ok but surges. This is the cheap throttle-less one and I was going to add a cable throttle but should I keep the vane & spring mechanism? If so how? Without it, it could of course run wide open, unless I install it so throttle won't fully open?
Oh, I put the on off coil kill switch on it, and new primer bulb (old one hard as plastic). Carb & tank are spotlessly clean.
Disregard. I fixed it. After posting I realized all I had to do was operate it manually first.
I had to fabricate a bracket for cable mounted to flywheel shield.
No more surging, it runs wherever it's set. It idles really low like I'm guessing 300 rpm. I cut about mid throttle.20200421_183014.jpg20200421_182944.jpg
/ Murray 3.5hp add throttle #4
Doing is learning. There is no substitute for experience.
You know that you have disabled the governor, right.
Yes. That vane/spring is the governor. When I get in tall grass I want her wide open!
Actually I hardly use it. The little I have and will it will be half throttle, maybe 2k rpm.
Coleman Powermate Generator (A62613)
Coleman Powermate...
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
(10) New CATERPILLAR Keys (A65579)
(10) New...
17109SFL (A61569)
17109SFL (A61569)
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
