Multi Axis Drawbar?
/ Multi Axis Drawbar? #1
IHF
New Hampshire
Kubota M9000
Hi,
I have a pronovost dump trailer with a clevis/swivel hitch (pulled with a Kubota L2250 or M9000). When in use on flat terrain there are no issues, but the drawbar has started to bend the clevis/swivel hitch when going over rough and uneven terrain. Looking for a solution to prevent any further damage to the trailer hitch. Thank you in advance for your help!
-Luke
/ Multi Axis Drawbar? #2
How about a pintle or combination pintle/ball hitch. There are all sorts of variations out there.
/ Multi Axis Drawbar? #4
/ Multi Axis Drawbar? #5
I think the pintle hitch or conversion to a ball and socket hitch would solve your problem. You have no rotational freedom with your current setup.
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
(4) Hydraulic Cylinders (A65640)
(4) Hydraulic...
Camco Running Gear (A66408)
Camco Running Gear...
Concrete Mixer (A62613)
Concrete Mixer...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
