Mulching equipment
/ Mulching equipment #21
Take a look at the JCB skid steers. They have one that is side entrance that I saw at the national farm machinery show this year. IMG_9248.JPG
/ Mulching equipment #22
AKFish - The MeriCrusher you ran, does it have the screen to size the chips? I've only recently heard of the brand but I understand the screen makes a big difference wrt getting the chips small enough to plant into without making several passes. Thanks for the info.
Jim
KW Land Works
Forestry Mulching - KW Land Works, LLC.
Jim, no screen to size the wood chips on the MeriCrusher that I used. The company has a number of different models. So, I wouldn't know how the others are set up.
Just to clarify a bit more... The MeriCrusher is not directly like a Fecon or ASV. Those machines are more like a chipper/grinder.
The MeriCrusher is more like a roto-tiller on steroids! It does chip and grind some... But the brush/trees are broken down and churned over and buried into the ground leaving a semi-packed seedbed.
They (M-C) has a website with videos that illustrate the machines.
There is one additional, clear difference between a MeriCrusher and a Fecon, etc. You would never want to use a MeriCrusher in a rocky area or anyplace that has outcrops or boulders. You'd destroy the carbide teeth in seconds!
The Fecon head can be "carefully" worked in those areas to clear brush, etc.
/ Mulching equipment #23
Hi
We're importing MeriCrusher to North America. From about 30ish to >700hp. Working depths to 16", working widths to >12 feet. Many tool, rotor and other options.
We're making a commitment to spare parts availability.
PM me is you would like any additional information.
Thanks in advance,
/ Mulching equipment #24
Just FYI The first MeriCrusher machines with screen will arrive in North America about June 1. You're correct, the screen can be a game changer.
Lot of 2 ForeRunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Lot of 2...
WACKER NEUSON  LTN8 LIGHT PLANT (A68842)
WACKER NEUSON...
2023 Chevrolet Tahoe SUV (A66738)
2023 Chevrolet...
2017 Mack Semi (A64047)
2017 Mack Semi...
Polaris Ranger 4x4 Gas Utility Cart (A66734)
Polaris Ranger 4x4...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
