Mulching equipment
/ Mulching equipment #21
Take a look at the JCB skid steers. They have one that is side entrance that I saw at the national farm machinery show this year. IMG_9248.JPG
/ Mulching equipment #22
AKFish - The MeriCrusher you ran, does it have the screen to size the chips? I've only recently heard of the brand but I understand the screen makes a big difference wrt getting the chips small enough to plant into without making several passes. Thanks for the info.
Jim
KW Land Works
Forestry Mulching - KW Land Works, LLC.
Jim, no screen to size the wood chips on the MeriCrusher that I used. The company has a number of different models. So, I wouldn't know how the others are set up.
Just to clarify a bit more... The MeriCrusher is not directly like a Fecon or ASV. Those machines are more like a chipper/grinder.
The MeriCrusher is more like a roto-tiller on steroids! It does chip and grind some... But the brush/trees are broken down and churned over and buried into the ground leaving a semi-packed seedbed.
They (M-C) has a website with videos that illustrate the machines.
There is one additional, clear difference between a MeriCrusher and a Fecon, etc. You would never want to use a MeriCrusher in a rocky area or anyplace that has outcrops or boulders. You'd destroy the carbide teeth in seconds!
The Fecon head can be "carefully" worked in those areas to clear brush, etc.
/ Mulching equipment #23
Hi
We're importing MeriCrusher to North America. From about 30ish to >700hp. Working depths to 16", working widths to >12 feet. Many tool, rotor and other options.
We're making a commitment to spare parts availability.
PM me is you would like any additional information.
Thanks in advance,
/ Mulching equipment #24
Just FYI The first MeriCrusher machines with screen will arrive in North America about June 1. You're correct, the screen can be a game changer.
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2019 Nissan Versa Sedan (A66738)
2019 Nissan Versa...
2014 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
FIXED FIFTH WHEEL ATTACHMENT (A68842)
FIXED FIFTH WHEEL...
PORTA POTTY (A68842)
