Muffler mods
/ Muffler mods #1
kubota2234
Taylorsville, NC
2008 Kubota L3400 4x4 , 1992 Ford 1710, 2003 Ford F-250 4x4, 1993 Ford F350 4x4 Dump truck, 2005 20ft Hudson brothers trailer, 1996 Hoop 16' trailer
Anyone done them? Just thinking about doing it to some of my saws and was going to get opinions
/ Muffler mods #2
I have not I assume you want more horse power I have seen that mentioned here before. I myself have a Coleman 5000 watt generator and it is very loud. We only use it if the power goes out for a day or so, and thankfull that does not happen often.I would like to buy an after market replacement to bolt on and quiet that beast down. If anyone reads this and knows what I can try please let me know.
/ Muffler mods
Well I am looking for something to open up a couple of my saws. I know there isnt alot of hp to be gained, but a choked up as the inside of the mufflers are, it has to make the saw run better.
/ Muffler mods #5
Depends on the saw how much you will gain. On a MS290 I seen 23% quicker 1 cut times after muffler mod and carb re-tune. Seen about the same gains on MS390 I just did.
/ Muffler mods
Cool Deal Guys!!! Thanks, Ill start there. XYZ thanks for the additionl info also
/ Muffler mods #7
Jeff Lary, I also have a 5000 watt generator that is loud and sometime back I was looking into a different muffler to quiet it down. In my research on it I read that just adding a muffler to it would add too much back pressure and the solution was to go to a motorcycle shop and get a muffler made for a 2 cycle ATV. These quieted them down and did not create the back pressure. Most shops have stock ones they have taken off new bikes for cheap.
One other thing is that these types of generators have a lot of mechanical noise. You quiet down the exhaust but the generator parts themself make a lot of noise. Solultion was to make a enclosure to put the gen in with the backside open pointed away from the house.
In the end I decided to save my $ and get a dedicated standby generator for the house.
/ Muffler mods #8
yea thanks i will look into that Idea.I could afford a better one but even if i spent $3000.00 it would sit as much as the $300.00 one does.
/ Muffler mods #9
Muffler mods are great on some saws, but they all respond differently.
IMO, the higher end saws have more to gain vs the lower end saws.
And if I remember correctly, I think the # is 80%
That means, take the muffler off and measure the exhaust port. You want the muffler opening to be ~80% of what the port is:thumbsup: So you can either open up the existing hole more or add another hole to get to the 80%:thumbsup:
/ Muffler mods #10
Ya mean an expansion chamber, like on the saw competion circuit? I'v had them on trailbikes..Noisy, but effective..
/ Muffler mods #11
muffler mods? nah......lmao
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
2018 Peterbilt 579 (A64127)
2018 Peterbilt 579...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
Ledwell Hydratail 48Ft Trailer (A64194)
Ledwell Hydratail...
2024 Better Built 7'x12' Trailer (A64127)
2024 Better Built...
