MTD yardman push mower surging
/ MTD yardman push mower surging #1
AroniaFarmer
Sioux City IA
TYM T603 52' Ford 8N
I have just recently got a free yardman push mower. It looks like it has a Honda clone engine on it. When I got it home one governor linkage was off, but nothing else looked bad on it. I put new gas in it and started it. It was surging and running rough unless the choke was on or it was under a heavy load cutting some tall grass. Is this a governor issue or a carb issue?:confused:
/ MTD yardman push mower surging #2
Carb needs cleaned. But check the price of new carb, because kit plus time may cost more than the carb itself.
I cleaned the carb with carb cleaner and blew it out with compressed air over 2 times now and it still runs like crap. I think I am going to buy a new carb for it
/ MTD yardman push mower surging #4
Make sure you have good gas flow into the carb. Things like junk clogging or partially clogging the fuel line, or stick float needle valve can cause your symptoms.
2020 BROWN AND HUBERT 10' SPOOL TRAILER (A63276)
2020 BROWN AND...
213138 (A64276)
213138 (A64276)
2025 Good Luck Go Cart (A64557)
2025 Good Luck Go...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
JOHN DEERE PUMPING UNIT (A64278)
JOHN DEERE PUMPING...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
