MTD log splitter bogs down and stalls
/ MTD log splitter bogs down and stalls #1
Robbie0125
Baton rouge
MTD 522
I知 having a problem with a MTD 522 log splitter. Motor binds and stalls when under a load. I changed the coupling and spider gear. I haven稚 run any pressure test. It will start splitting, then bind and stall the motor.
/ MTD log splitter bogs down and stalls #2
Could be the Governor. Google engine governor. I had the same issue with a tiller. Governor linkage had come loose and it would run perfect until the tines touched the soil then it would bog and die.
/ MTD log splitter bogs down and stalls #3
Is the carb mixture adjustable? Sometimes the jets get partially blocked with gum from the gas and it will have no power. Maybe you could open the jet a little or clean the carb. I don't know if that's the problem, just a suggestion.
/ MTD log splitter bogs down and stalls #4
Is this definitely a motor issue, and not a matter of the ram on your splitter binding under load?
/ MTD log splitter bogs down and stalls #5
If this is a Hi-lo log splitter pump is it possible the sequence valve for shifting from hi to low is stuck or malfunctioning. Like John states, you need to determine if this is an engine problem or a hydraulic problem.
New/Unused Landhonor LHR-CSC10 Squeeze Chute (A65583)
New/Unused...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
2006 PROCO  130BBL (A65643)
2006 PROCO 130BBL...
