MT357 Codes
/ MT357 Codes #1
KCTractors
Central Wi
LS MT357, Case 530 CK, , Ford 2000, , Ford 8N, Moline 602
My MT357 has regened twelve times now in twenty-five hours. Last two times it was one hour of running. Today it showed some codes , it showed like a open book with the letter S and number 3253 and on the bottom of that there was F11 and to the right of that the number 81.
The Dealer is closed today so I'll have to wait for Monday.
Anybody have a clue what these numbers mean?
/ MT357 Codes
/ MT357 Codes #3
B-011 - DIFFERENTIAL PRESSURE SENSOR (DPS) (Sensor)
Differential pressure sensor - Technical Data (55.989)
Engine control system - Component localization - Electrical sensors (55.015)
s3253 F07 (P224A) - DP sensor leak detected (55.640)
s3253 F07 (P244A) - DP sensor leak detected (55.640)
s3253 F11 (P1453) - DP sensor tube Clamped (55.640)
s3253 F11 (P1452) - DP sensor tube inverted (55.640)
s3253 F02 (P2453) - DP sensor plausibility fault (55.640)
s3253 F03 ( P2455) - DP sensor high fault (55.640)
s3253 F04 ( P2454) - DP sensor low fault (55.640)
s81 F00 (P2458) - DPF overload fault (55.640)
s81 F07 (P2463) - DPF plugged fault (55.640)
s81 F11 (P242F) - DPF regeneration error (55.640)
/ MT357 Codes #4
Sounds like a bad sensor or your dpf is plugged. How many hours total on the tractor? Just 25? That low, its probably a bad sensor. The tractor is sensing a plugged dpf and trying to clear it out. Not being successful, its throwing codes. Call the dealer on Monday, if its under warranty, it should be 100% covered (minus travel. My dealership, if they have to come get it, they will charge me. Warranty only covers shop time).
/ MT357 Codes
Yes, It just has 25 hours on it.
/ MT357 Codes #7
You could have one of sensor tubes broken or blocked, sensor unplugged or a sensor failure.
That sensor is near the top of the DPF cannister with 2 hoses one to the DPF the other to the DOC. 3 wire connector to it.
/ MT357 Codes
I took the tractor back this morning. They said it has something to do with the anti-freeze getting into the DPF cannister and telling the ECM that it needs to regen. I don't know if that is right because the coolant bottle didn't go down. They said that wouldn't take much to send the code. I'll keep the board informed.
/ MT357 Codes #9
I can not think of a good way antifreeze can get into the exhaust, it implies coolant is making from the water jacket to the exhaust or into the engine in my little mind.
/ MT357 Codes #10
Sounds like a possible leak (small) in the EGR cooler. Thats the only way, besides a cracked head, cracked block, or blown head gasket, that I can think of anyway for coolant to get into the DPF. This is all assuming the mechanic is correct about the coolant getting into the DPF in the first place. Fortunately, the EGR cooler is easy(ish) to replace. Again, this should be a warranty thing. Please keep us updated.
/ MT357 Codes
I believe that's what the service man said, EGR cooler. He said that he has changed a few of them already.
/ MT357 Codes #13
Leaking EGR coolers is a known issue. My dealer has replaced several of them. It can be verified by removing and inspecting the EGR valve. Sometimes they have green coolant in them, and sometimes baked on coolant that looks like black shiny varnish. There should only be dull black soot, not shiny varnish. The DPF can be inspected by removing the ends from the canister. There should only be dull black or dark grey on the surfaces inside. Coolant contamination will cause brown stains and can not be cleaned out by doing a regen. I have a picture of it but can't find it right now. If there is lots of brown in there, the DPF has to be replaced because regens will not remove it. The 5 year emissions warranty will cover it even after the 2 year full warranty is over.
/ MT357 Codes #14
I finally found the picture of the DPF with coolant contamination inside. It should only have dull grey or black in it, brown stains are from coolant. No amount of regens will clean it out, so it tells the ECU that the soot level is still too high after a regen, so it wants to regen again. This one was caused by a leaking EGR cooler which is in the other picture. You can see the shiny varnish from baked on coolant. Sometimes you can see green coolant in there too.
/ MT357 Codes
Just a follow-up on my MT357 regen problem from August 2024. Tractor still regens every ten hours now. I only have 45 hrs on it now. It hasn't been snowing here in Wisconsin so I haven't been using the tractor much. Sitting in a nice warm garage. I still not happy with every ten hours. I don't idle it much either. I had a MT342 that would regen every 50 to 60 hours.
/ MT357 Codes #16
Yeah, that isn't right. I've got 30 hours on a TYM and not a single regen request
Hayrack Wagon (A66408)
Buckhorn Poly Feed Box (A66408)
Buckhorn Poly Feed...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2018 Trail King Lowboy (A63689)
2018 Trail King...
