MT3 Crank position sensor location??
/ MT3 Crank position sensor location??
On my wife's honda I had to jack the engine up to get to the sensors on the engine. That was an all day affair. Helps that the engine is not covered with body parts fer sure.
Your manual was a big help thanks.
I'm glad I didn't have to clear the fault codes to get it back running. That would have taken longer than the fix. I have an OBDII scan tool but it didn't like the tractor for some reason. It worked 1x but didnt pick up the fault then I couldn't get it to communicate with the tractor.
/ MT3 Crank position sensor location?? #12
Eagle 1 is correct. Search part codes on parts. I worked in Cnc automation for engine and trans lines. Most parts are sourced from only a hand full of companies. Perfect example. My arctic cat snowmobile. AC wants $380 for the 2 injectors. I searched the number. It was a $13-17 injector used on several common Toyota and Honda cars. Even had the 3 different symbols to id what flow injector.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
