MT1601D hydraulics
   / MT1601D hydraulics #1
bigcheese
Ferris, Texas
Mitsubishi MT1601D
Messed up and left tractor out in hard rain, transmission shifter boot is torn and water contaminated hydraulic oil. Drained and flushed system twice, but cannot get hydraulics back up and working other than implement lift will raise slowly, used to raise fast. Did I mess up the pump too? Have flow but no high pressure.
Yes, mine uses standard hydraulic oil in the trans which is the hydraulic resorvoir.
   / MT1601D hydraulics #4
You've probably got air in the system and you'll have to work the control valve some more to bleed it off. If you don't have a loader installed, use 80 wt gear oil. The shift boot is cheaper that the oil you've bought. Email me for a quote. Bill - satohparts.com.
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
UNUSED AGT 32-743 60" HYD GRAPPLE (A51248)
UNUSED AGT 32-743...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2016 CAT TL642C (A50123)
2016 CAT TL642C...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
