Mowing Mowing rocky field
/ Mowing rocky field #1
brande
I hope one of you can straighten me out.
Recently purchased about 15 acres, used as corn field and built house and barn there.
When mowing, I come across all kind of rocks turned up by the farmer's plow.
From softball size to bowling ball size.
I try to watch, but still hit a rock now and then, much to my mower's dismay.
It seems that
I have removed about a tri-axle truck load of rocks out of there, but there is more mowing and rocks to do.
I do have field grass and clover growing well, so I don't really want to turn the whole field. I will if I have to, though.
Also-when mowing across, I hit lump after lump from where the corn rows were-any easy way to flatten?
Been lurking here for a while-I know one of you can get me going!!
Many Thanks
brande
Kubota L3400-hey, do they make a turbo for this??
Bush Hog 84" RD finish mower.
/ Mowing rocky field #2
I would rake it.
The rake would knock down the humps and also grab most of the rocks.
-Duane
I've never used a rake before, but doesn't a rake have spring like tines?
If so, it might spring right over many rocks as many are mostly below surface, with a little sticking out above-think of an iceberg. I typically use a flat bar to dig under them to lift out.
Will a rake work??
Thanks
brande
/ Mowing rocky field #4
With my mowing of virgin ground, I set the rotary cutter at it's highest setting (10.5 inches) and walk the area before I mow, marking and/or removing obstacles when I find them. I am piling up rocks all over. Then I come back with the FEL and scoop them up. Now I have a growing rock pile!
Bob
I got a pile of field rocks, much like you.
What do we do with these??
I found one guy building a pond who was happy to haul away what
he could. About a third of the pile.
He hasn't been back, and I still have about a tri-axle truck of rocks to get rid of.
The pile keeps GROWING!! Can I sell these things?
All field grade sandstone.
Help me, please!!
Good Luck
brande
/ Mowing rocky field #6
Will a rake work??
Thanks
brande
You are right about a rake. The rocks need to be loose first. Box blade rippers will do the job of loosening the rocks. When it's all done, it will have been a big job no matter what - make it as easy as possible!
Terry
/ Mowing rocky field #7
Brande,
I would take rocks from you - but I dont think you are in Virginia. Landscaping places sell rocks here by pallet.
/ Mowing rocky field #8
4-sale @#$!!! rocks. Big ones, little ones, fat ones ,skinny ones, white ones, dark ones, light ones, rock, rock, rock!!!!!!!!!!!!!!!!!1
/ Mowing rocky field #9
We are luckier. We have bricks. Old hand made brick from an old house. One bvay we can build a new house. The bricks don't tend to stick but the CEO does not like the horses to step on them. They make great borders around gardens.
/ Mowing rocky field #10
I too have piles and piles of rocks.
There are no hard labor camps near me to have the prisoners work chipping them down to size unfortunately.
Has anyone dug a big hole and buried their rockpile in the back forty as a solution?
/ Mowing rocky field #11
My rocks "grow" too - they keep moving up from the frost action the past winter. Every few years I put on my backhoe and go around popping out the worst offenders. Sometimes they are big - so I dig a hole next to 'em and roll them down into it. Figure another 20 years of this and the field will be done.
/ Mowing rocky field #12
Another one of my jobs to do. Get rid of rocks.
If you got rid of all the rocks in the ADKs, you'd be below sea level!
UNUSED SDLANCH SDLL580 RIDE ON SKID STEER (A64280)
UNUSED SDLANCH...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
2021 KUBOTA SVL75-2 SKID STEER (A64279)
2021 KUBOTA...
2025 IRANCH IREAS Wood Grab Grapple Mini Excavator Attachment (A61572)
2025 IRANCH IREAS...
2022 Mercury Verdado 300HP Outboard Boat Motor (A61574)
2022 Mercury...
