Henro
Super Member
- Joined
- Jul 4, 2003
- Messages
- 5,007
- Location
- Few miles north of Pgh, PA
- Tractor
- Kubota B2910, BX2200, KX41-2V mini EX
Rise over run (or drop over run) gives the tangent of the angle if my memory is still good... /forums/images/graemlins/blush.gif
A while back I made a little spread sheet to calculate the angle...I think it works right...
Plugging your numbers in gives an slope of 14.7 degrees...I think I got it right, and that seems like a reasonable angle...maybe someone can confirm it.
If you have a calculator with math functions all you do is take the arc tan of the rise over run, and the calculator should display the angle. (unless it is set up to work with radians,that is...in which case you need to do a further conversion from radians to angle).
