mowing grass around a pond?
/ mowing grass around a pond? #1
zzbudzz
i'm helping my mother-in-law keep up the pond behind her house .i need some guidance on the best way to cut the grass and cattails around the pond.she has a 4wd drive kobota tractor (i can't remember what model 410? with front loader) anyway we have a 6 bushhog ,but i can't get close to the waters edge especially on the dam's bank.would a sickle bar mower work well for this task?i can't seem to find much information on them or how much do they cost? thanks in advance!
/ mowing grass around a pond? #2
sickle bar is the only way drop it down in the waters edge and cut away
/ mowing grass around a pond? #3
May not work in every application, but it does in mine. I have a New Holland 451, 7' bar, 3-point sickle bar that hasn't cut the first lick of hay. All it does is cut pond banks, ditch lines, under trees when I'm bush hogging the pastures, and to clippastures every now and then. I use 1/2 the fuel to cut pastures with the sickle bar as when I use the bush hog.
/ mowing grass around a pond? #4
Depending on how much you have to mow, someone here posted a homemade 3PH mower. He like took a push mower and built a frame so it could hang off to the right six or so feet. A hand winch allowed him to lower it below center. This allowed him to keep his tractor on solid ground (no sloping).
If you have access to a welder and/or know someone who could build it, might not be any more expensive than a sickle mower......
Ron
ok , thanks for the information! /forums/images/graemlins/smile.gif
/ mowing grass around a pond? #7
It seems like the area around a pond would be a good place for ground cover that doesn't need mowed. Alternatively, rather than try to figure out how to mow it, maybe it's time to think outside the tractor box. Push mowers aren't that dreadful, heck even using a scythe to trim down ornamental grasses and cattails might not be so bad as the likelyhood rolling over the tractor into the pond.
Cliff
/ mowing grass around a pond? #8
I like the ground cover idea Cliff. It sounds like a much better solution than having to cut close to the pond bank.
Cutting weeds and letting them fall into the pond is another problem. It wouldn't look too great, and may even foul the water.
I think 1 pygmy goat per acre of pond would also work pretty good. /forums/images/graemlins/smile.gif
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
2022 EZ-GO ELITE...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2014 Hyundai VI2530112 53ft. T/A Dry Van Trailer (A64556)
2014 Hyundai...
2020 Freightliner CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 Freightliner...
