Mowing deck bolts
   / Mowing deck bolts #41
Just called the dealer and ordered a set of blades... $57, and he's delivering them this afternoon. Gotta love that service. Now I just have to stop by Lowe's on the way home for the 30mm socket. :thumbsup:
   / Mowing deck bolts #42
For those interested...
30mm = 30 x 0.03937 = 1.1811
1 3/16" = 1.1875
the difference between them is 0.0064"
... that is less than 7 thousanths of an inch.
IMHO either should work fine... six or twelve point...
(most impacts are 6 point)
   / Mowing deck bolts #43
The 30 mm socket goes back to 2002...When the BX22 came out..
Also we have a wonderful tool called search function here..
   / Mowing deck bolts #44
Paid under $9 at Advance Auto and Lowe's has it for under $9. I'm sure either place will take a return if it's the wrong size but mine was 30MM from Advance.
That's it, thanks much.
   / Mowing deck bolts #45
Interesting. What size and material type (sand, carbide, micro-diamond) grit? I use an angle grinder, which goes quite fast, but sometimes too fast, perhaps taking off more material than I want.
It never occured to me to use a belt sander, as I figured that was too slow. I can see how it would keep a more planar bevel face though, than the angle grinder. Maybe I could rough with the angle grinder and finish with the belt sander...Hmmmm.......
Yea, would appreciate knowing grit type and size. Thanks in advance.
I'm not the original poster but I also use a belt sender to sharpen my blades. I use a Ryobi 4X36" bench top unit with either 50 or 80 grit belts depending on how many rocks I've been cutting. If it's real bad I'll start with the angle grinder first.
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A49461)
2012 Ford F-550...
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
100GAL L SHAPED FUEL TANK (A50854)
100GAL L SHAPED...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
