Mowing deck bolts
/ Mowing deck bolts
JT-It's true, the shipping is more than the part. By the time I shopped around town for it, the savings of $3 wouldn't be worth the time, so I went ahead and ordered it online today.
It was clear that you already have what you need. You probably realize the info. I posted is simply for the benefit of others who may be considering their options. It is a good idea. Thanks for sharing it. Next time I take the blades off I'll be able to save a little time. Time seems to be as valuable a commodity as money these days. Every bit helps.
Time was the reason I had to buy locally. I wasn't willing to wait 3 to 4 days to get it.:) I let my fingers find it and had my wife pick it up when she drove past Advance. Internet showed Lowe's had it for under $9 but that would have required another mile out of the way.:) I believe in options and I appreciate members on this post telling where and for how much something can be bought. The one on Amazon that you referenced is probably a better socket for the more frequent user. I think it's made for air impact wrenches.
/ Mowing deck bolts #22
Well, I almost got around to sharpening the blades on my 2230. Then I found a new demo 2350 on a local lot with full warrantee.
The dealer is doing a fullservice on and and it should be delivered within the next few days. Now I don't have to sharpen the blades for at least another year!!! :laughing:
/ Mowing deck bolts #23
I use....the belt sander to sharpen ... [the] blades.
Interesting. What size and material type (sand, carbide, micro-diamond) grit? I use an angle grinder, which goes quite fast, but sometimes too fast, perhaps taking off more material than I want.
It never occured to me to use a belt sander, as I figured that was too slow. I can see how it would keep a more planar bevel face though, than the angle grinder. Maybe I could rough with the angle grinder and finish with the belt sander...Hmmmm.......
Yea, would appreciate knowing grit type and size. Thanks in advance.
/ Mowing deck bolts #24
Well, on my 33'' cub cadet walk behind that I use for the rental property, I don't even take the blades off. Dremel makes an attachment that sharpens the blades right on the mower. Only bad part is you can't tell if they are balanced, but I have never had any problem.
WB
/ Mowing deck bolts
Well, on my 33'' cub cadet walk behind that I use for the rental property, I don't even take the blades off. Dremel makes an attachment the sharpens the blades right on the mower. Only bad part is you can't tell if they are balanced, but I have never had any problem.
WB
Is this what your talking about? Does it grind down enough to take the nicks out of the blade? How do you get it under the mowing deck? How many blades will it do? Had this for a few years but never got it out of the package, yet? This is the picture with my new blades installed.
/ Mowing deck bolts #26
Yes, it will grind the big nicks out, just takes a while. it will usually do both of my blades before I have to get a new stone. I just prop up my mower, but if you have the deck off, it should be pretty easy. Maybe you could put it on some ramps to avoid taking off the deck, but that sounds a little iffy.
WB
/ Mowing deck bolts
WB
I've got a little push mower that I'll use it on since you say it works well. I've already swapped out the 3 blades on my deck with new ones and have the old ones ready to sharpen off of the deck. I've also got a front end loader to raise it off the ground if I were going to do it on the deck. Thanks.
/ Mowing deck bolts #28
That's (1 3/16") what Kubota mechanic said they use in a 6pt only not 12 point. Guess the 30MM is the exact and the 1 3/16" is close enough if 6 point. Don't have either but going to have wife pick up a 30MM 12 point since that's what they (Advance Auto) shows they have on internet for $8.19. So for $60 for blades and $8.19 for socket I can start cutting grass again instead of just breaking it.:)
You will be much better with the 6pt socket because there will be no chance for it to slip as opposed to that 12pt which willslip if there are even small imperfections on the bolt-nut.
It's all I have used for the last 35yrs and it doesn't give me any worries at all.
One other thing John try to use a torque wrench instead of the air gun as they can tighten up so much that sometimes the nuts- bolts may have to be torched off. Don't ask me how I know LOL.
Regards
DGS
/ Mowing deck bolts
Regards
DGS
Your several days to late. Done bought the exact size 12pt 30 MMM and if fit perfect and not the least bit worried, To late on the air wrench, done done it and will never go back. I don't have a torque wrench anymore and haven't had one in 20 years and have never missed it. But thanks.
/ Mowing deck bolts
John, PLEASE, PLEASE, PLEASE tell me you put jack stands under the axles or blocks under the wheels before you crawl under there!!!
I didn't, I didn't, I didn't. I should have, I should have, I should have. I think there is enough clearance laying flat under it that it wouldn't have crushed me but I'm first going to check it and then I'll probably put something under the wheels in the future.
/ Mowing deck bolts #32
Entertaining and informative thread :D
re. air compressor and impact wrenches. If one does their own mechanical maintenance, this IS the way to go. There is SO MANY uses for this setup that it would take a thread all it's own to detail :D But, to touch on thr OP's basic message, mower blades, wheels and just about any fastner that fastens to a movable object becomes mere fodder for an impact wrench to remove and replace :D
Only negative is the cost to get started.
A very good alternative that has already been mentioned is the 3/4" drive electric impact wrench. I have both and there are times when one works better than the other....
Same sockets work for either too...
re. blades. I would recommend either the OEM HI lifts or going w/a gatorblade over the std OEM's. I know I'm late to the party but I offer this for future readers of this fine thread.
The advantages are basically a better cut and better clipping disbursion. Either works very well w/baggers too. Std OEM's are fine but if you want to take it to the next level :D
re. sharpening, I use a hand grinder and file to sharpen my gatorblades and I do it atleast once a yr at the beginning of the season but it's not unusual to do them again should I "feel" the cut is regressing.
I'm going on my 4th season on these gators and so far they've held up better than any blade I've used before. But like everything, Oregon had come out w/a new latest and greatest and I've been considering a change. The ones that have caught my eye are the new Magnum 3-1 Hi lift mulcher blades. Supposedly they have 40% more lift than the std/OEM's and std gators of yrs past.
Again, blade tip speed, sharp edges, coupled w/higher lift equates to what the commerical high $$$ mowers achieve and what customers happily pay for...
re. doing ones own maintenance. Bravo!
Back in the day farming/Lawn & garden machinery required frequent scheduled maintenance and those that could "wrench" their own eqt were well ahead of the game. Modern machinery's scheduled maintenance is alot easier and is less frenquently required although they are much more complicated to repair. The good thing is w/ the required scheduled maintenance being done when required lessens the likelyhood of complicated repairs, and when one can do their own they get a much better ROI. Plus one learns their machinery much better.
re. working under heavy machinery, ALWAYS use jackstands and or something similar for support. Murphys law as well as the proverbial "gotcha" will getya when one least expects it.... :D
Well, breaks over gotta get back to the grind. Helpful threads such as this that lead to entertaining reply's are, well entertaining, and beg for long after the fact reply's :D
Dave
/ Mowing deck bolts #33
I think there is enough clearance laying flat under it that it wouldn't have crushed me ....
I'm particularly thinking of you crawling under a still mounted MMM to use that Dremmel tool on still mounted blades. There's about enough clearance for a chihuahua (assuming deck is in up position). BTW, no disrespect intended to anyone, Dremmel's have their place, but IMHO this is undersized for the job.
I spent one summer during college working in a machine shop. There was one full time guy and I on the punch presses. The presses had been built shortly after the Civil War (no joke) when a steam engine and huge leather belts turned all machinery in a factory. The little startup company jerry rigged electric motors to the drive mechanisms and put "safety buttons" on each hand. The parts would not eject correctly between each stamping. We figured out a way to hold down the safety buttons with our elbows and whack each part stamped out from between the press with a 10" long piece of 1 x 1/2 trim pine. Our rhythm had to be perfectly timed. Every 20 min. or so, the press would misfire and the lower half of that stick would be converted to a thin piece of veneer. About two summers later, I worked there again. That other guy was now working as a floor sweeper. When I saw one of his fingers missing, I didn't have to ask why.
And the moral of this story is: "Never, never, never become complacent when working around powerful/heavy equipment. Respect it the way you would a crocodile if you were its feeder in a zoo. It may look as docile as a statue, but it will have you for lunch before you know what's happened."
/ Mowing deck bolts
I agree. Seen to many injuries. I wouldn't get under the deck, I was under tractor when deck was/is removed.
/ Mowing deck bolts
Dave
I think I bought an entire air tools kit at Lowe's for around $50. I think it was a big sale maybe Black Friday or a clearance so actually if one owns a compressor already it is fairly cheap to get it. Don't know how any one can be without a compressor for wood construction and/or mechanical. The set I bought even had the sockets plus alot of other stuff. Sure it was over $100 regular price.
/ Mowing deck bolts #36
I've got the RCK60 mid-mount-mower on my B7800 Kubota. I assume this also is a 30mm socket? TIA!!
/ Mowing deck bolts #37
Regular sockets have been known to shatter using an impact air gun. We've all done it, but we know we shouldn't. (use regular sockets on an impact) I think I'd rather a guy bought some Harbor Freight or some such cheap impact sockets than use even the better standard sockets. Not the safety police, just sayin'.
The six sided impact sockets are the right tool. Necessity is sometimes the mother of invention and innovation, but next time you are at an estate sale or flea market or Harbor Freight type place, pick up a set of 6 sided, deep well, impact sockets. They can be gotten very cheaply. Grab a set in both metric and SAE. Oil your gun too once in awhile.:thumbsup:
/ Mowing deck bolts #38
Please don't mow your deck bolts. Your blades won't like it very much.
/ Mowing deck bolts
This socket is $30 so I would like to make sure I have the right one before I purchase. TIA!
Paid under $9 at Advance Auto and Lowe's has it for under $9. I'm sure either place will take a return if it's the wrong size but mine was 30MM from Advance.
