mower won't lower
/ mower won't lower #1
faz
binghamton
kubota bx 2200
My BX 2200 Kubota mid mount mower won't lower. I took the handle of and put vise grips on it and it won't move. Any ideas?
/ mower won't lower #2
:welcome:
I'm going to move this thread over to our Kubota section to see if we can get you an answer.
/ mower won't lower #4
3 things to check, lower/lift 3 point lever on the side, should be lowered, lower speed rate knob below seat, and the height setting knob below seat.
If height setting is at the top, raise 3 point all the way to take pressure off cam and then set height and lower.
If the lower rate knob is closed all the way and jammed, you need to get penetrating oil along shaft and move back and forth until it breaks loose and then keep lubricated and move every so often so it does not do it again.
David
/ mower won't lower #5
David
I believe you'll find your answer above. The speed of drop/lower rate control knob was my problem a couple of times.
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2005 International 4300 Rollback (A62613)
2005 International...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
2024 ROADCLIPPER HDT207 T/A 22FT TILT TRAILER (A59914)
2024 ROADCLIPPER...
