mower won't lower
/ mower won't lower #1
faz
binghamton
kubota bx 2200
My BX 2200 Kubota mid mount mower won't lower. I took the handle of and put vise grips on it and it won't move. Any ideas?
/ mower won't lower #2
:welcome:
I'm going to move this thread over to our Kubota section to see if we can get you an answer.
/ mower won't lower #4
3 things to check, lower/lift 3 point lever on the side, should be lowered, lower speed rate knob below seat, and the height setting knob below seat.
If height setting is at the top, raise 3 point all the way to take pressure off cam and then set height and lower.
If the lower rate knob is closed all the way and jammed, you need to get penetrating oil along shaft and move back and forth until it breaks loose and then keep lubricated and move every so often so it does not do it again.
David
/ mower won't lower #5
David
I believe you'll find your answer above. The speed of drop/lower rate control knob was my problem a couple of times.
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2014 BMW X1 S28i SUV (A61574)
2014 BMW X1 S28i...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
2004 Quincy QSI500 Air Compressor (A61572)
2004 Quincy QSI500...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
