Mower suggestion - Keep or Start-Over
/ Mower suggestion - Keep or Start-Over #1
r0GuE
Veteran Member
West PA
ex-Bota Owner
I'm moving to a smaller place. 0.7 acre lawn, pretty flat with a little downward slope to the front lawn. I will no longer have easy access to a place to dump grass clippings.
I have a 12 y/o Kubota BX2200 with a 60" deck, a rear bagger and a FEL. I just sold the FEL so I'm got a bit of cash coming in from that.
So the decision I'm contemplating is selling the remaining BX gear and getting a Zero Turn of some type with mulching blades. The theory is that I'd be shifting up to new (although my BX probably has more years lft in it than me). I'd be going mulching blades so I would not longer have the dumping the clippings issues. And perhaps the Zero Turn is more appropriate for that scale of property. And -- hopefully -- I would come out about even on the deal cash wise.
Thoughts my friends?Should I down size it? Should I get a Zero Turn or just a small mower. Should I just add a mulching kit and sell my rear PTO bagger?.... It just seems like a waste to have a rear PTO and 4WD never to be used again, and inefficient with the 3 cyl diesel running wide open, just to mow a little lawn....
/ Mower suggestion - Keep or Start-Over #2
What if you wanted to till up a garden, change the landscaping or do snow removal (if needed, can't see your location)?
Personally i think i'd keep the BX, but don't know the landscape. A zero turn is great for a huge lawn or many lawns, but mowing is really its only purpose. Tractors ar much more versatile.
/ Mower suggestion - Keep or Start-Over #3
I would keep the BX, better to have it and not need it than to need it and not have it. Do you need to pickup leaves in the fall or push snow? A BX is big enough to run aerators,rakes and other tools youmay need in the future for maintenance.
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
2000 GMC C7500 (A60736)
2000 GMC C7500...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Railroad Maintenance Machine (A61570)
Railroad...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2017 FREIGHTLINER CASCADIA (A60736)
2017 FREIGHTLINER...
