Mower Question: RMM vs. MMM
/ Mower Question: RMM vs. MMM #1
tractor_newbee
Ohio
Looking
I am in the market for my first tractor, but am not sure whether to get a Rear mounted mower or a Belly mounted mower. I will most likely purchase a Kubota B7500 or BX2200 (but that's a whole other issue!) I will be finish mowing about 2 ac. around my house. I don't have too many trees in the yard, and not too much landscaping (but I intend to add a few more flower beds). I have a lot of experience running tractors from working on a farm when I was younger, and used to bush-hog quite a bit. But... the only finish mowing I have done is with push-type or small lawn tractors.
It seems to me that the RMM would be harder to follow the lines of landscaping, and to get around the few trees I have, but easier to get in to areas the MMM might not be able to get due to it's location. I have also been told by a few farmer friends never to buy a MMM for two reasons: 1-Too hard to remove when you don't want it on. 2-Problems with belts, pullys, etc. make them more prone to problems. The price of the MMMs seems to be about double the RMM which is also a factor.
So...Rear mount or Belly mount. What do you recomend and why?
Thanks for the help!
/ Mower Question: RMM vs. MMM #2
John,
It sounds like you have the pro's and con's lined out fairly well. I'd think going with a rear mount mower would be cheaper and allow you to spend some money on a small mower to use to "trim" around your landscaping.
Just a thought. /w3tcompact/icons/smile.gif I hope this helps.
/ Mower Question: RMM vs. MMM #3
if you read back your own post, you will notice that you pretty much answered your query. MMM are good for small or landscaped sites. They do cost more,are more of a workout to remove plus you ll need a tractor with a mid PTO,which spells even more $$$. Unless you plan to turn your place into Kew Gardens go with the rear-mount.
/ Mower Question: RMM vs. MMM #4
Rear mount gives you the choice of side or rear discharge. Few mid-mounts are made as rear discharge.
/ Mower Question: RMM vs. MMM #5
I gotta go with the rear mount. Since my tractor also gets a lot of loader time, I just can't dedicate it to having a MMM full time do to ground clearance issues. As far as the maneuverability issue goes. Well it just becomes second nature to you by the 3rd or 4th mowing as to where that mower is back there.
I would like to suggest that you go with a rear discharge, no side discharge chute sticking further out to one side. And less clumping and windrowing. But do get a model that extends out @ 6" on either side of the rear wheels. This makes it easier to get up against a fence or other object. Remember that on the B7500 you can have the wheels extended farther out for more stability.
Speaking of the B7500, it gets my vote over the BX2200. Just more of a tractor. and you can hang a bigger loader on it. Oh yeah you might want consider a loader. Its like having an extra hand and two extra backs. Most useful tool you will ever own.
/ Mower Question: RMM vs. MMM #6
Welcome to TBN,
I'm going to take the other side of this discussion. I've got a TC21D with a MMM, and FEL. I have about 3 acres of grass to mow. The tractor sixe, and lawn size are very similar to what you are talking about here. I'm very, very pleased with my MMM. I can get as close to trees, and flower beds, as I did with my Garden Tractors. The yard looks as good as when I mowed with my Wheel Horse, and Craftsman. Taking the MMM is no problem with my FEL. I just lift the front of the tractor off the ground. Putting it back on is a little hard, due to positioning the mower itself. I found that if you are on a level surface, it takes about 15 minutes. This issue has been discussed before, and the debate still goes on. I can tell you , that I'm very, very happy with my MMM. Good Luck, Kent
/ Mower Question: RMM vs. MMM #7
Hi,
I went with a RFM and I am basically satisfied with my decision. I have only used it twice so far.
At this point I think I should have went with a 72 inch unit over the 60 inch that I bought. I have a little extension beyond the rear tires, but could use more. I like the rear discharge that I have, which is a Woods RD6000 model.
Cutting close to a fence takes a little getting used to, as the movement of the mower, as related to the steering wheel, is opposite to that of the MMM. In other words, the MMM moves with the front wheels, the RFM opposite to them.
THe RFM goes on and off pretty easily. Actually really easily. I have to drop my backhoe to put on the RFM, and that is the hardest part of mowing.
An advantage of the RFM that I liked was the ability to back to a ditch and cut right to the edge. BUT, to do this you have to pick up the RFM with your 3PH, because in the normal mode the RFM runs on the ground, supported by its own wheels, and the back wheels will drop off the ditch edge otherwise, sending the blades into the ground. [I figured this out beforehand, so I did not do any rototilling...]
With a hst transmission, I don't mind stopping and backing up in some tight places. A real pleasure as compared to using the old MTD garden tractor.
All in all, I think going with the RFM was the right decision for me. IF you go with a RFM and regret it, you will likely be able to see it much easier than you could sell a MMM, which is generally brand specific, from what I understand. THe RFM is a 3PH attachment that will work on just about anyone's tractor.
The RFM does stick out the back a bit more than I had expected, but I don't find this to be much of a concern, if at all.
Attached is a photo of my B2910 with the RFM on it...
Bill Macher in Pgh, PA...
/ Mower Question: RMM vs. MMM #8
Hey Bill,
That's a nice looking setup, that you got there. Go Steelers!!!!/w3tcompact/icons/smile.gif
Kent
/ Mower Question: RMM vs. MMM #9
I had a 6' RFM on my old tractor and now have a 6' MMM with this tractor. So after having both I like the MMM. I think it cuts better by not having the rear tires go over the grass before the mower deck. Its alot easier to get close to trees and landscaping with the MMM and I don't have to keep looking back! I can take my deck off in less than 5 min. so that is not a problem. I find there are some places I can't cut with the MMM, and others that I now can that I couldn't before with the RFM. The only thing that I miss is being able to raise the mower up 2 ft. to clean it.
/ Mower Question: RMM vs. MMM #10
In addition to backing up to mow ditches, the RFM is great for backing under low branched trees, like pines and cedars.
/ Mower Question: RMM vs. MMM #11
I also went throug the same questions (MMM vs rear PTO mower). I have about 3 acres of yard, flower beds and some trees. In both cases rear or MMM you will still have use a push type mower to get into those hard to access areas (there are less of them with a MMM) or turn that area into new flower beds (wich I have done), I also mow the my 5 acre field with the MMM. The MMM is more expemsive but I am very pleased with the quality of the cut. As far as the removing and reattaching the rear mower is obviously easier but I takes me less than three minutes to change my MMM.
So I don't think attaching and removal of a MMM should be the deciding factor. Good Luck on your decision!
/ Mower Question: RMM vs. MMM #12
To add to what others have said, your tractor choice should also help determine what mower you decide to choose. The best reason to get the BX is being able to use the excellent MMM. I can attach/disconnect mine as quickly as a RFM, and it does a wonderful job. If you decide on a RFM, then you might as well get the 7500 with the advantages the bigger tractor will give you.
/ Mower Question: RMM vs. MMM #13
I would recommend a RFM for you, but let my give you some background fist. The BX2200 comes with a 60" MMM that weighs 250lbs. The B7500 comes with a 60" MMM that weighs 350lbs and is made frm 9.5 gauge steel. Since you are looking for a small chasis CUT, the heaviest MMM in this class belongs to NH TC18-24 models. The 60" MMM on these models come in rear and side discharge, weighing 425 and 475 lbs. These decks are made from 7 gauge steel. This is probably meaningless, since you probably wouldn't select a CUT based on its MMM. Your mower will probably be your highest wear attachment that you will own, so finding the heaviest duty mower available is what I recommend, and that's why I suggest a RFM. You will have a choice of brands and construction. Look how they are made. How much they weigh. How long is their warranty.
Personally, I have a midsize chassis NH with a MMM. I have a lot of trees, and consider the MMM the best way to go for me. Seven gauge steel is my minimum requirement, since have experienced cracks on thinner decks, and have had to weld and reweld them. To be fair, JD also has a 7 gauge steel MMM for their midsize CUTs. This MMM is actually stamped from a single piece of steel.
/ Mower Question: RMM vs. MMM #14
I went with a FMM (front mount mower) /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
Excellent cut, greater visibility, can get closer than a MMM on tight radius curve changes on either side and into corners like a RMM. Removes or attaches in 30 seconds (that's no exageration, I've got films to prove it). Rear discharge blows under the tractor and leaves little windrow in heavy grass. Lifts over 3 feet off the ground for easy under deck cleaning too. Also, brush hogging with a front mount brush hog is much easier than a 3pt hitch.
But... since you have your heart set on the big K (excellent machines in my opinion) you might want to look at the Woods line of rear mount mowers. They appear to be very well built and give a very nice cut. Here's a clickable link to their website and the rear discharge mower page.<A target="_blank" HREF=http://www.woodsequipment.com/catalog/tg_finish8.html>http://www.woodsequipment.com/catalog/tg_finish8.html</A>
If I were going to buy a tractor with a 3pt hitch, this is the mower that I would buy. Let us know what you decide. /w3tcompact/icons/smile.gif
/ Mower Question: RMM vs. MMM #15
I have a B7500 with a MMM. Have never used a RDM on it, so I can't comment on that. However, on the ease of taking the MM off, it's not hard at all. Just need to raise the front end (either with FEL or blocks), unhook three pins, undo the PTO, and slide it out. Takes about five minutes on a concrete garage floor.
/ Mower Question: RMM vs. MMM #16
I have a 60" MMM on my B7500 and love it, I can trim close to stuff most the time and my weedeating is more along the ditches and banks than around trees.
Using a RFM you have to remember your mower is behind you so you have to drive past things to turn since it's turning wider than the tractor, on in other words your tractor is longer behind you and if you ain't careful you'll knock it against the car, house, wife or whatever.
/ Mower Question: RMM vs. MMM #17
"To add to what others have said, your tractor choice should also help determine what mower you decide to choose."
I agree with the statement above. The BX has an excellent MMM that is very easy to install and remove. However, not having a lot of experience with a RFM, I would think that you would limit your self to some of the smaller units with the BX. If you decide on the RFM you may as well get the larger tractor as well.
/ Mower Question: RMM vs. MMM #18
I have a 72" FC RFM that I use behind my New Holland TC33D (The Mid size chasis).
I bought it to maintain my 2 acres. But I have also use it to mow my yard at my current house. My whole front yard is about 40' by 25' with a lot of curved flowerbeds. I get some really strange looks form my neighbors but seat time is seat time/w3tcompact/icons/laugh.gif!
It makes my yard look better than when I use my 22" walk behind mower and manuvers around the free form curved beds with ease. I hardly have to even trim with the line trimmer al all.
I would sugest the RFM with the larger tractor. Can't go wrong with that combo IMO!
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
2011 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2011 FOREST RIVER...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2016 Cadillac XTS Sedan (A61574)
2016 Cadillac XTS...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
